sabin26
(Sabin Neupane)
January 2, 2024, 7:07am
1
I am trying to setup caddy as a reverse proxy for my self-hosted supabase with docker compose. I followed the steps from Reverse-Proxy self-hosted Supabase with Caddy but I am getting a blank page.
Windows 10 Pro, Docker
docker compose --file docker-compose.yml up --detach
...[Same as supabase docker-compose.yml]
image: caddy:2.7.6
- "443:443/udp"
- ./volumes/caddy/Caddyfile:/etc/caddy/Caddyfile:Z
- ./volumes/caddy/data:/data:Z
- ./volumes/caddy/config:/config:Z
accounting.localhost {
@api path /rest/v1/* /auth/v1/* /realtime/v1/* /storage/v1/*
reverse_proxy @api supabase:8000
basicauth {
user hashedPassword
Self-Hosting with Docker | Supabase Docs
Mohammed90
(Mohammed Al Sahaf)
January 2, 2024, 7:27am
2
You don’t need this
Supabase documentation is just telling you the endpoints where those services are served, they’re not for route-matching. Notice how, in the docs, the dashboard and the API are all served on :8000, you can change this:
To this:
reverse_proxy supabase:8000
sabin26
(Sabin Neupane)
January 2, 2024, 7:35am
3
As per your suggestion, I changed my CaddyFile.
To:
But, Now the page is not accessible at all.
accounting.localhost can’t currently handle this request.
Mohammed90
(Mohammed Al Sahaf)
January 2, 2024, 7:45am
4
Please enable debug and access logging in Caddy and share the full logs.
I suspect you need to change this value
but we cannot know for sure without seeing logs of what every layer is seeing and reacting to.
sabin26
(Sabin Neupane)
January 2, 2024, 8:01am
5
I could not enable debug as it was an unrecognized directive. However, I accessed the logs and it says: tcp: lookup supabase on 10.89.0.1:53: no such host","request".
Make sure your Caddy container is in the same docker network as your supabase container. If they’re not in the same network, then there’s no route between the containers, and the docker DNS resolver can’t provide an IP address for that name.
sabin26
(Sabin Neupane)
January 2, 2024, 8:07am
7
I thought using supabase and caddy on the same docker-compose.yml file makes sure that both are in the same network ? Is it not ? Should I be doing something more ?
sabin26
(Sabin Neupane)
January 2, 2024, 8:16am
8
Here is my complete docker-compose.yml file:
# Usage
# Start: docker compose up
# With helpers: docker compose -f docker-compose.yml -f ./dev/docker-compose.dev.yml up
# Stop: docker compose down
# Destroy: docker compose -f docker-compose.yml -f ./dev/docker-compose.dev.yml down -v --remove-orphans
version: "3.8"
studio:
container_name: supabase-studio
image: supabase/studio:20231123-64a766a
healthcheck:
test:
"CMD",
"node",
"-e",
"require('http').get('http://localhost:3000/api/profile', (r) => {if (r.statusCode !== 200) throw new Error(r.statusCode)})"
timeout: 5s
interval: 5s
retries: 3
depends_on:
analytics:
condition: service_healthy
STUDIO_PG_META_URL: http://meta:8080
POSTGRES_PASSWORD: ${POSTGRES_PASSWORD}
DEFAULT_ORGANIZATION_NAME: ${STUDIO_DEFAULT_ORGANIZATION}
DEFAULT_PROJECT_NAME: ${STUDIO_DEFAULT_PROJECT}
SUPABASE_URL: http://kong:8000
SUPABASE_PUBLIC_URL: ${SUPABASE_PUBLIC_URL}
SUPABASE_ANON_KEY: ${ANON_KEY}
SUPABASE_SERVICE_KEY: ${SERVICE_ROLE_KEY}
LOGFLARE_API_KEY: ${LOGFLARE_API_KEY}
LOGFLARE_URL: http://analytics:4000
NEXT_PUBLIC_ENABLE_LOGS: true
# Comment to use Big Query backend for analytics
NEXT_ANALYTICS_BACKEND_PROVIDER: postgres
# Uncomment to use Big Query backend for analytics
# NEXT_ANALYTICS_BACKEND_PROVIDER: bigquery
kong:
container_name: supabase-kong
image: kong:2.8.1
# https://unix.stackexchange.com/a/294837
entrypoint: bash -c 'eval "echo \"$$(cat ~/temp.yml)\"" > ~/kong.yml && /docker-entrypoint.sh kong docker-start'
- ${KONG_HTTP_PORT}:8000/tcp
- ${KONG_HTTPS_PORT}:8443/tcp
depends_on:
analytics:
KONG_DATABASE: "off"
KONG_DECLARATIVE_CONFIG: /home/kong/kong.yml
# https://github.com/supabase/cli/issues/14
KONG_DNS_ORDER: LAST,A,CNAME
KONG_PLUGINS: request-transformer,cors,key-auth,acl,basic-auth
KONG_NGINX_PROXY_PROXY_BUFFER_SIZE: 160k
KONG_NGINX_PROXY_PROXY_BUFFERS: 64 160k
DASHBOARD_USERNAME: ${DASHBOARD_USERNAME}
DASHBOARD_PASSWORD: ${DASHBOARD_PASSWORD}
# https://github.com/supabase/supabase/issues/12661
- ./volumes/api/kong.yml:/home/kong/temp.yml:ro
auth:
container_name: supabase-auth
image: supabase/gotrue:v2.125.1
depends_on:
db:
# Disable this if you are using an external Postgres database
analytics:
healthcheck:
test:
"CMD",
"wget",
"--no-verbose",
"--tries=1",
"--spider",
"http://localhost:9999/health"
timeout: 5s
interval: 5s
retries: 3
GOTRUE_API_HOST: 0.0.0.0
GOTRUE_API_PORT: 9999
API_EXTERNAL_URL: ${API_EXTERNAL_URL}
GOTRUE_DB_DRIVER: postgres
GOTRUE_DB_DATABASE_URL: postgres://supabase_auth_admin:${POSTGRES_PASSWORD}@${POSTGRES_HOST}:${POSTGRES_PORT}/${POSTGRES_DB}
GOTRUE_SITE_URL: ${SITE_URL}
GOTRUE_URI_ALLOW_LIST: ${ADDITIONAL_REDIRECT_URLS}
GOTRUE_DISABLE_SIGNUP: ${DISABLE_SIGNUP}
GOTRUE_JWT_ADMIN_ROLES: service_role
GOTRUE_JWT_AUD: authenticated
GOTRUE_JWT_DEFAULT_GROUP_NAME: authenticated
GOTRUE_JWT_EXP: ${JWT_EXPIRY}
GOTRUE_JWT_SECRET: ${JWT_SECRET}
GOTRUE_EXTERNAL_EMAIL_ENABLED: ${ENABLE_EMAIL_SIGNUP}
GOTRUE_MAILER_AUTOCONFIRM: ${ENABLE_EMAIL_AUTOCONFIRM}
# GOTRUE_MAILER_SECURE_EMAIL_CHANGE_ENABLED: true
# GOTRUE_SMTP_MAX_FREQUENCY: 1s
GOTRUE_SMTP_ADMIN_EMAIL: ${SMTP_ADMIN_EMAIL}
GOTRUE_SMTP_HOST: ${SMTP_HOST}
GOTRUE_SMTP_PORT: ${SMTP_PORT}
GOTRUE_SMTP_USER: ${SMTP_USER}
GOTRUE_SMTP_PASS: ${SMTP_PASS}
GOTRUE_SMTP_SENDER_NAME: ${SMTP_SENDER_NAME}
GOTRUE_MAILER_URLPATHS_INVITE: ${MAILER_URLPATHS_INVITE}
GOTRUE_MAILER_URLPATHS_CONFIRMATION: ${MAILER_URLPATHS_CONFIRMATION}
GOTRUE_MAILER_URLPATHS_RECOVERY: ${MAILER_URLPATHS_RECOVERY}
GOTRUE_MAILER_URLPATHS_EMAIL_CHANGE: ${MAILER_URLPATHS_EMAIL_CHANGE}
GOTRUE_EXTERNAL_PHONE_ENABLED: ${ENABLE_PHONE_SIGNUP}
GOTRUE_SMS_AUTOCONFIRM: ${ENABLE_PHONE_AUTOCONFIRM}
rest:
container_name: supabase-rest
image: postgrest/postgrest:v11.2.2
depends_on:
db:
analytics:
PGRST_DB_URI: postgres://authenticator:${POSTGRES_PASSWORD}@${POSTGRES_HOST}:${POSTGRES_PORT}/${POSTGRES_DB}
PGRST_DB_SCHEMAS: ${PGRST_DB_SCHEMAS}
PGRST_DB_ANON_ROLE: anon
PGRST_JWT_SECRET: ${JWT_SECRET}
PGRST_DB_USE_LEGACY_GUCS: "false"
PGRST_APP_SETTINGS_JWT_SECRET: ${JWT_SECRET}
PGRST_APP_SETTINGS_JWT_EXP: ${JWT_EXPIRY}
command: "postgrest"
realtime:
# This container name looks inconsistent but is correct because realtime constructs tenant id by parsing the subdomain
container_name: realtime-dev.supabase-realtime
image: supabase/realtime:v2.25.35
depends_on:
db:
analytics:
healthcheck:
test:
"CMD",
"bash",
"-c",
"printf \\0 > /dev/tcp/localhost/4000"
timeout: 5s
interval: 5s
retries: 3
PORT: 4000
DB_HOST: ${POSTGRES_HOST}
DB_PORT: ${POSTGRES_PORT}
DB_USER: supabase_admin
DB_PASSWORD: ${POSTGRES_PASSWORD}
DB_NAME: ${POSTGRES_DB}
DB_AFTER_CONNECT_QUERY: 'SET search_path TO _realtime'
DB_ENC_KEY: supabaserealtime
API_JWT_SECRET: ${JWT_SECRET}
FLY_ALLOC_ID: fly123
FLY_APP_NAME: realtime
SECRET_KEY_BASE: UpNVntn3cDxHJpq99YMc1T1AQgQpc8kfYTuRgBiYa15BLrx8etQoXz3gZv1/u2oq
ERL_AFLAGS: -proto_dist inet_tcp
ENABLE_TAILSCALE: "false"
DNS_NODES: "''"
command: >
sh -c "/app/bin/migrate && /app/bin/realtime eval 'Realtime.Release.seeds(Realtime.Repo)' && /app/bin/server"
storage:
container_name: supabase-storage
image: supabase/storage-api:v0.43.11
depends_on:
db:
rest:
condition: service_started
imgproxy:
healthcheck:
test:
"CMD",
"wget",
"--no-verbose",
"--tries=1",
"--spider",
"http://localhost:5000/status"
timeout: 5s
interval: 5s
retries: 3
POSTGREST_URL: http://rest:3000
DATABASE_URL: postgres://supabase_storage_admin:${POSTGRES_PASSWORD}@${POSTGRES_HOST}:${POSTGRES_PORT}/${POSTGRES_DB}
FILE_SIZE_LIMIT: 52428800
STORAGE_BACKEND: file
FILE_STORAGE_BACKEND_PATH: /var/lib/storage
TENANT_ID: stub
# TODO: https://github.com/supabase/storage-api/issues/55
REGION: stub
GLOBAL_S3_BUCKET: stub
ENABLE_IMAGE_TRANSFORMATION: "true"
IMGPROXY_URL: http://imgproxy:5001
- ./volumes/storage:/var/lib/storage:z
imgproxy:
container_name: supabase-imgproxy
image: darthsim/imgproxy:v3.8.0
healthcheck:
test: [ "CMD", "imgproxy", "health" ]
timeout: 5s
interval: 5s
retries: 3
IMGPROXY_BIND: ":5001"
IMGPROXY_LOCAL_FILESYSTEM_ROOT: /
IMGPROXY_USE_ETAG: "true"
IMGPROXY_ENABLE_WEBP_DETECTION: ${IMGPROXY_ENABLE_WEBP_DETECTION}
meta:
container_name: supabase-meta
image: supabase/postgres-meta:v0.75.0
depends_on:
db:
analytics:
PG_META_PORT: 8080
PG_META_DB_HOST: ${POSTGRES_HOST}
PG_META_DB_PORT: ${POSTGRES_PORT}
PG_META_DB_NAME: ${POSTGRES_DB}
PG_META_DB_USER: supabase_admin
PG_META_DB_PASSWORD: ${POSTGRES_PASSWORD}
functions:
container_name: supabase-edge-functions
image: supabase/edge-runtime:v1.29.1
depends_on:
analytics:
SUPABASE_SERVICE_ROLE_KEY: ${SERVICE_ROLE_KEY}
SUPABASE_DB_URL: postgresql://postgres:${POSTGRES_PASSWORD}@${POSTGRES_HOST}:${POSTGRES_PORT}/${POSTGRES_DB}
# TODO: Allow configuring VERIFY_JWT per function. This PR might help: https://github.com/supabase/cli/pull/786
VERIFY_JWT: "${FUNCTIONS_VERIFY_JWT}"
- ./volumes/functions:/home/deno/functions:Z
command:
- start
- --main-service
- /home/deno/functions/main
analytics:
container_name: supabase-analytics
image: supabase/logflare:1.4.0
healthcheck:
test: [ "CMD", "curl", "http://localhost:4000/health" ]
timeout: 5s
interval: 5s
retries: 10
depends_on:
db:
# volumes:
# - type: bind
# source: ${PWD}/gcloud.json
# target: /opt/app/rel/logflare/bin/gcloud.json
# read_only: true
LOGFLARE_NODE_HOST: 127.0.0.1
DB_USERNAME: supabase_admin
DB_DATABASE: ${POSTGRES_DB}
DB_HOSTNAME: ${POSTGRES_HOST}
DB_SCHEMA: _analytics
LOGFLARE_SINGLE_TENANT: true
LOGFLARE_SUPABASE_MODE: true
# Comment variables to use Big Query backend for analytics
POSTGRES_BACKEND_URL: postgresql://supabase_admin:${POSTGRES_PASSWORD}@${POSTGRES_HOST}:${POSTGRES_PORT}/${POSTGRES_DB}
POSTGRES_BACKEND_SCHEMA: _analytics
LOGFLARE_FEATURE_FLAG_OVERRIDE: multibackend=true
# GOOGLE_PROJECT_ID: ${GOOGLE_PROJECT_ID}
# GOOGLE_PROJECT_NUMBER: ${GOOGLE_PROJECT_NUMBER}
# Comment out everything below this point if you are using an external Postgres database
db:
container_name: supabase-db
image: supabase/postgres:15.1.0.117
healthcheck:
test: pg_isready -U postgres -h localhost
interval: 5s
timeout: 5s
retries: 10
command:
- postgres
- -c
- config_file=/etc/postgresql/postgresql.conf
- -c
- log_min_messages=fatal # prevents Realtime polling queries from appearing in logs
# Pass down internal port because it's set dynamically by other services
- ${POSTGRES_PORT}:${POSTGRES_PORT}
POSTGRES_HOST: /var/run/postgresql
PGPORT: ${POSTGRES_PORT}
POSTGRES_PORT: ${POSTGRES_PORT}
PGPASSWORD: ${POSTGRES_PASSWORD}
PGDATABASE: ${POSTGRES_DB}
POSTGRES_DB: ${POSTGRES_DB}
- ./volumes/db/realtime.sql:/docker-entrypoint-initdb.d/migrations/99-realtime.sql:Z
# Must be superuser to create event trigger
- ./volumes/db/webhooks.sql:/docker-entrypoint-initdb.d/init-scripts/98-webhooks.sql:Z
# Must be superuser to alter reserved role
- ./volumes/db/roles.sql:/docker-entrypoint-initdb.d/init-scripts/99-roles.sql:Z
# Initialize the database settings with JWT_SECRET and JWT_EXP
- ./volumes/db/jwt.sql:/docker-entrypoint-initdb.d/init-scripts/99-jwt.sql:Z
# DATA is persisted between restarts
- ./volumes/db/data:/home/postgresql/data:Z
# Changes required for Analytics support
- ./volumes/db/logs.sql:/docker-entrypoint-initdb.d/migrations/99-logs.sql:Z
image: caddy:2.7.6
- "443:443/udp"
I guess its with the naming: supabase
It’s not a directive, it’s a global option. See Caddyfile Concepts — Caddy Documentation which explains the structure of a Caddyfile.
I don’t see any containers called supabase in your stack. Which one has the HTTP server? Use that container’s name.
Is it kong? Then you should proxy to supabase-kong:8000
sabin26
(Sabin Neupane)
January 2, 2024, 8:36am
10
francislavoie:
supabase-kong:8000
Yes, Instead of hosting supabase and caddy side by side, I hosted caddy inside the supabase scope. Thus, I needed to use kong as the reverse proxy instead of supabase . It worked. Thank you for your support!
