[reverse proxy] Caddy redirecting correctly, site still NOT secure
v2.2.1
sudo caddy start (Ubuntu command line)
Ubuntu, NOT a docker install
sudo caddy start
n/a
http://www.xxxxs.tk {
reverse_proxy 127.0.0.1:8096
redirect a URL to the specific port I have setup for a Jellyfin media server and provide HTTPS security, the redirect is happening but the site is still not secure (no HTTPS).
EDIT: Found this as I was looking through console messages:
http    server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server {"server_name": "srv0", "http_port": 80}
Capture
I’ve checked and rechecked the DNS settings, the Caddyfile, and the console feedback on startup. I have ALLOWED ports 443 and 80 through the Ubuntu firewall.
Replying to my own post as I have solved it (not deleting it in case my mistake is made by others).
Caddyfile should NOT contain “http://” before the URL or (it seems) caddy will ONLY listen on the HTTP port and not automatically create HTTPS for you.
Thanks for sharing the solution!
Indeed, specifying http:// means that Caddy will do what you say, and serve only HTTP, not HTTPS. Caddyfile Concepts — Caddy Documentation
