Reverse proxy and self-signed certificate
Two servers
  • Server A
    • Caddy v2.4.6
    • FQDN with Let’s Encrypt TLS certificate
    • reverse proxy to server B on port 881
  • Server B
    • Caddy v2.4.6
    • IP (no FQDN)
    • listening on port 881 (non TLS)
Server B is behind a router that forwards the external port 881 to the internal port 881 on server B.
The traffic between a client and server A is TLS encrypted but not the traffic forwarded from A to B.
How can I generate a self-signed certificate on B and tell the reverse proxy to use that certificate ( tls_insecure_skip_verify ) ?
Caddyfile server A
    # reverse proxy to server B
    serverB.example.com {
        reverse_proxy * http://123.123.123.123:881
            output file /var/log/caddy/serverA.log
Caddyfile server B
    :881 {
        root * /var/www
        php_fastcgi unix//var/run/php/php7.4-fpm.sock
            output file /var/log/caddy/serverB.log
This should explain everything you need to know:
