v2.5.1
Ubuntu, right from the binary (./caddy)
./caddy run
handle_path /.well-known/matrix/client {
respond "{"m.homeserver": {"base_url": "https://example.com"}}"
header Access-Control-Allow-Origin "*"
I need to return JSON with double quotes.
Error during parsing: Wrong argument count or unexpected line ending
Using/adding backslahes
6. Links to relevant resources: Return a static text with double quote json
Hi
I posted a more elaborate response regarding static json responses in the context of matrix servers before, which I highly recommend to you here
But just for the record, you could use both backslashes \ or backticks `:
The Caddyfile Concept docs (hotlink to “Tokens and quotes”) state:
Quotes can be escaped if you need to use quotes in quoted tokens, too:
directive "\"abc def\""
You can also use a backtick ` to quote tokens; these are convenient when tokens themselves contain double quotes, e.g. JSON text:
directive `{"foo": "bar"}`
