Remove index.php from {uri} (rewrite)
Currently i’m trying to migrate my nextcloud installation from nginx to caddy.
Is almost works, but some images don’t load. Icons and stuff.
I tracked it down to the rewrite rules.
All links to working and not working images look the same: https://example.com/index.php/apps/theming/img/core/filetypes/folder-external.svg?v=13
Some of them load, some of them get redirected and return nothing.
However, when i remove the index.php part from the images which won’t load, it works.
I’m currently struggling writing the rewrite rule, i tried different things, but non of them seemed to work.
I’m using 1to1 this config: examples/Caddyfile at master · caddyserver/examples · GitHub
It seems like the following nginx rule is missing in this caddy config
    location ~* \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
        try_files $uri /index.php$uri$is_args$args;
I tried already something like this:
    rewrite {
        to {uri} {uri}/ /index.php?{uri}
but it just gets worse. I think the main problem is, that index.php is part of uri. Is there any way i can remove it?
Hi @TrAnn3l, welcome to the Caddy community. Your avatar is my favourite PD2 mask!
Rewrite comes with regex capabilities, so you could remove the index.php part that way.
Going off your example: https://example.com/index.php/apps/theming/img/core/filetypes/folder-external.svg?v=13
rewrite {
  if_op or # proceed if any of the following is true:
  if {path} ends_with svg
  if {path} ends_with gif
  if {path} ends_with png
  if {path} ends_with html
  if {path} ends_with ttf
  if {path} ends_with woff
  if {path} ends_with ico
  if {path} ends_with jpg
  if {path} ends_with jpeg
  r ^/index.php/(.+)$
  to /{1}
Hey @Whitestrake, thanks for your help.
It is almost working, only one images is not loading (404 not found):
https://example.com/index.php/apps/theming/img/core/filetypes/folder.svg?v=13
And again, when i manually remove the index.php it is loading. I have no idea why the rewrite is not triggering.
I put your rewrite first, so there should be nothing intercepting.
In addition, i changed your code a little bit and used the ext directive
Update:
Adding /index.php?{1} to the to directive fixed it
My code looks now like:
example.com {
	root   /var/www/nextcloud
	log    /var/log/nextcloud_access.log
	errors /var/log/nextcloud_errors.log
	fastcgi / 127.0.0.1:9000 php {
		env PATH /bin
    rewrite {
        r ^/index.php/(.+)$
        to /{1} /index.php?{1}
    rewrite {
		r ^/index.php/.*$
		to /index.php?{query}
	# client support (e.g. os x calendar / contacts)
	redir /.well-known/carddav /remote.php/carddav 301
	redir /.well-known/caldav /remote.php/caldav 301
	# remove trailing / as it causes errors with php-fpm
	rewrite {
		r ^/remote.php/(webdav|caldav|carddav|dav)(\/?)$
		to /remote.php/{1}
	rewrite {
		r ^/remote.php/(webdav|caldav|carddav|dav)/(.+?)(\/?)$
		to /remote.php/{1}/{2}
	rewrite {
		r ^/public.php/(.+?)(\/?)$
		to /public.php/(.+?)(\/?)$
	status 403 {
		/.htacces
		/data
		/config
		/db_structure
		/.xml
		/README
	header / Strict-Transport-Security "max-age=31536000;"
Till now, nextcloud is the only site which still requires a lot of rewrites.
I will make a PR to update the example.
Nice! Can’t believe I forgot about that.
