I followed instructions over at Docker Hub to set up a Nextcloud “Base version - FPM” container (built with cron added) along with abiosoft’s caddy container. The caddyfile settings I used are essentially the ones from examples/Caddyfile at master · caddyserver/examples · GitHub. Nextcloud appears to work just as fine with this setup as it did before when I used caddy as a reverse proxy only but the url now always includes index.php/, as in
nc.mydomain.com/index.php/login
instead of nc.mydomain.com/login
. Apparently other users got it right (Remove index.php from {uri} (rewrite)). Is there anything obvious that I’m missing or that I am doing wrong?
My Caddyfile currently contains:
nc.mydomain.com {
root /srv/nextcloud
log /Caddylog/nextcloud_access.log {
rotate_size 10 # Rotate after 10 MB
rotate_age 14 # Keep log files for 14 days
rotate_keep 10 # Keep at most 10 log files
errors stdout
fastcgi / nextcloud:9000 php {
root /var/www/html
# checks for images
rewrite {
r ^/index.php/(.+)$
to /{1} /index.php?{1}
rewrite {
r ^/index.php/.*$
to /index.php?{query}
# client support (e.g. os x calendar / contacts)
redir /.well-known/carddav /remote.php/carddav 301
redir /.well-known/caldav /remote.php/caldav 301
# remove trailing / as it causes errors with php-fpm
rewrite {
r ^/remote.php/(webdav|caldav|carddav|dav)(\/?)$
to /remote.php/{1}
rewrite {
r ^/remote.php/(webdav|caldav|carddav|dav)/(.+?)(\/?)$
to /remote.php/{1}/{2}
rewrite {
r ^/public.php/(.+?)(\/?)$
to /public.php/(.+?)(\/?)$
status 403 {
/.htacces
/data
/config
/db_structure
/.xml
/README
header / Strict-Transport-Security "max-age=31536000;"
tls me@myhost.com
The relevant section of the docker-compose.yml is
caddy-certs:
nextcloud-data:
image: abiosoft/caddy
restart: always
depends_on:
- nextcloud
- ./Caddyfile:/etc/Caddyfile
- ./Caddylog:/Caddylog
- caddy-certs:/root/.caddy
- nextcloud-data:/srv/nextcloud:ro
nextcloud:
build: .
restart: always
- nextcloud-data:/var/www/html
