I have status pages which are located at addresses like https://app.pingr.io/status/{id}
Now I want users to be able to use custom domains which will be redirected using CNAME.
To begin with this task I decided to try something simple. When user goes to https://status.pingr.io I want that he’s proxied to https://app.pingr.io/status/Mlm1zrAx/. The “Mlm1zrAx” is just hardcoded for now. But of course I want that it’d be transparent for user, meaning it’s not a redirect but proxy, so that url doesn’t change.
Next step is to proxy: custom-domain.com → https://app.pingr.io/status/custom-domain.com, so that I can link users domain to my status page.
I know that I probably missing something simple, and I don’t fully understand web servers configuration.
What I tried is I actually created the caddyfile, and tried to use rewrite + reverse_proxy.
However what I get right now, is that files served from app.pingr.io have wrong Content-Type. All files (css/js) have text/html, so as a result I got " We’re sorry but pinger doesn’t work properly without JavaScript enabled. Please enable it to continue."
The difference is that this will prefix all URLs, but what you were doing was rewriting all URLs to just /status/Mlm1zrAx, meaning every request, even the ones for JS files, were being rewritten to exactly /status/Mlm1zrAx. Instead, I think you want to proxy to /status/Mlm1zrAx/js/app.js or something like that.
Hm, I guess not. Look, the js/css files are located at https://app.pingr.io/js/....
So, when user goes to status.pingr.io it should behave like he opened app.pingr.io/status/{id}. And if I go directly to app.pingr.io/status/{id}, then all the js/css are loaded at app.pingr.io/js/...
I don’t know if it may help, but previously when I tried to do this with nginx, I found a sample config which had sub_filter and he kind of replaced ulrs in html code or something like that
Strange, right now I get redirected to the login page.
However if I go to https://app.pingr.io/status/Mlm1zrAx it’s not under authorization, I can see the page I need.
I’m not sure I understand rewrite directive correctly.
If I have rewrite * /bar, it means that if I go to site.com/foo I’ll get redirected to site.com/bar, right?
Then, even if rewrite / /status/some-id is better it shouldn’t affect. In my case if I entered status.pingr.io/whatever/whatever... I’ll get get proxied to app.pingr.io/status/id, right? Like, no matter what user typed after site.com/, I’ll get redirected exactly to /status/some-id
Path matching in Caddy v2 is exact-match, so rewrite / /bar will only rewrite requests on / and will not rewrite requests on /foo.
The reason you’re getting kicked to the login page is likely because the authentication cookie is only stored for the app.pingr.io domain, and not status.pingr.io
Ah well, so do I get it right. I go to status.pingr.io and receive javascript files from app.pingr.io. These javascript works like “When user on the root route “/” he should be redirected to login page”. Since the javascript doesn’t know that he was served from /status/{id}.
So I need to have a separate repository for status.pingr.io I guess…
