Plugins having build issues as of 05/06/2019
I tested each plugins separately and here’s the list of those that don’t build on Download Caddy :
tls.dns.cloudxns - @matt
tls.dns.dnsmadeeasy - @matt
tls.dns.dnspod - @matt
http.authz - Build issues on caddyserver.com · Issue #1 · casbin/caddy-authz · GitHub - Fixed 05/06/2019
http.awses - Build issues on caddyserver.com · Issue #3 · miquella/caddy-awses · GitHub
http.geoip - Build issues on caddyserver.com · Issue #14 · aablinov/caddy-geoip · GitHub
http.locale - Build issues on caddyserver.com · Issue #6 · simia-tech/caddy-locale · GitHub
I believe last 4 could be corrected by using a valid release version tag in the form v0.1.0 or v1.0.0.
I’m unsure on the 3 dns provider plugins.
Ref: Plugin authors: Please deploy at semantic version tags or specific commits
Ohhhh thank you for doing this!!! I will take a look at the DNS provider plugins. (Maintaining those is such a pain. I need to improve that…)
I just haven’t gotten around to contacting each plugin author yet so thank you for opening those issues!
Would these be merged into a single one if the change discussed here is applied?
Is it planned in the near future?
Probably not, but I want to make a way to deploy a whole batch of plugins at once.
Also, the whole thing about “one plugin per repo” (which I fudged on with the DNS provider plugins since they’re so small and similar) might go away now that we’ve switched to Go modules. Will have to look into it more.
