v2.4.0-beta.1 built from the master including the Cloudflare module
I use Caddyfile rather than JSON.
FreeNAS 11.3 (a FreeBSD derivative)
service caddy start
n/a
This is an extract from the relevant section of my Caddyfile that I’m looking at enhancing.
udance.com.au www.udance.com.au {
import tlsdns
import logging udance
import authproxy /phpmyadmin*
reverse_proxy /tautulli* 10.1.1.26:8181
reverse_proxy /transmission* 10.1.1.28:9091
reverse_proxy 10.1.1.55
To avoid cluttering the above extract, I’ve not included the snippets. For completeness, I’ve included them below.
(tlsdns) {
dns cloudflare [REDACTED]
(authproxy) {
basicauth {args.0} {
admin [REDACTED]
(logging) {
format json
output file /var/log/caddy/{args.0}.log {
roll_keep 7
The Caddy block serves the domain and two sub-paths. I wanted some flexibility around taking individual services offline and thought that the map directive (which I’ve recently become a big fan of) could help me here.
Here’s my attempt at building this flexibility into the Caddy block with the focus, at this stage, just on the /tautulli sub-path. I noticed that there was a redirect to udance.com.au/tautulli/auth/login?redirect_uri=/tautulli if I entered udance.com.au/tautulli in a browser address bar, therefore, I had to use a regular expression for the path.
import tlsdns
map {path} {backend} {online} {
# PATH BACKEND ONLINE
~^/tautulli.* 10.1.1.26:8181 yes
# /transmission 10.1.1.28:9091 yes
# / 10.1.1.55:80 yes
default unknown yes
# Error handling
@unknown expression `{backend} == "unknown"`
handle @unknown {
respond "Denied {path}" 403
@offline expression `{online} == "no"`
handle @offline {
# Do whatever e.g. respond/redir
reverse_proxy {path} {backend}
The solution works approximately 50% of the time. Reloading the page seems to randomly switch me between the Tautulli login screen or the browser responding with a 502 error.
There are invalid dial address entries in the Caddy log file with missing port address. Here’s a couple of entries:
{"level":"error","ts":1615865654.7320564,"logger":"http.log.error.log3","msg":"making dial info: upstream {http.request.uri.path}:invalid dial address /tautulli/home: address tautulli/home: missing port in address","request":{"remote_addr":"10.1.1.136:57213","proto":"HTTP/2.0","method":"GET","host":"udance.com.au","uri":"/tautulli/home","headers":{"Authorization":["Basic YWRtaW46OComQXZLTFJ0SCUyITJGaUFlZQ=="],"Upgrade-Insecure-Requests":["1"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""],"User-Agent":["Mozilla/5.0(Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.82 Safari/537.36"],"Accept-Language":["en-GB,en-US;q=0.9,en;q=0.8"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["navigate"],"Sec-Ch-Ua-Mobile":["?0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Encoding":["gzip, deflate, br"],"Cookie":["tautulli_token_5837b2dff06e4f0e9f86551fd6ec5efc=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJ1c2VyX2lkIjoxNTQzNTU3LCJ1c2VyIjoiYmFzaWxoIiwidXNlcl9ncm91cCI6ImFkbWluIiwiZXhwIjoxNjE4NDU2NzU2fQ._BgPiEFn3XchkSRdY6SsWfAmebv58it-waZ84Clf1r0; tk_or=%22%22; tk_lr=%22%22; wordpress_logged_in_01ad53d5bf4f84d52a16c29bd439eb90=basil%7C1645606391%7Cg0BlFaRlmpOtRQIufy2y3zkZMaJQ5kBwHgodcQZTCol%7C21fc4a76a8a48a1988b5664d18c3115b251ad355646ec0b0bbf00b4cd0c0aa34; wp-settings-1=libraryContent%3Dbrowse; wp-settings-time-1=1614070400;__cfduid=d9d479562ae0d9e9a028d749d6594ad101615662603"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"udance.com.au"}},"duration":0.00032652,"status":502,"err_id":"uf8m3q16a","err_trace":"reverseproxy.statusError (reverseproxy.go:827)"}
{"level":"error","ts":1615865657.5854928,"logger":"http.log.error.log3","msg":"making dial info: upstream {http.request.uri.path}: invalid dial address /tautulli/home:address tautulli/home: missing port in address","request":{"remote_addr":"10.1.1.136:57213","proto":"HTTP/2.0","method":"GET","host":"udance.com.au","uri":"/tautulli/home","headers":{"Cache-Control":["max-age=0"],"Sec-Fetch-User":["?1"],"Accept-Language":["en-GB,en-US;q=0.9,en;q=0.8"],"Authorization":["Basic YWRtaW46OComQXZLTFJ0SCUyITJGaUFlZQ=="],"Sec-Ch-Ua":["\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""],"Upgrade-Insecure-Requests":["1"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["navigate"],"Cookie":["tautulli_token_5837b2dff06e4f0e9f86551fd6ec5efc=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJ1c2VyX2lkIjoxNTQzNTU3LCJ1c2VyIjoiYmFzaWxoIiwidXNlcl9ncm91cCI6ImFkbWluIiwiZXhwIjoxNjE4NDU2NzU2fQ._BgPiEFn3XchkSRdY6SsWfAmebv58it-waZ84Clf1r0; tk_or=%22%22; tk_lr=%22%22; wordpress_logged_in_01ad53d5bf4f84d52a16c29bd439eb90=basil%7C1645606391%7Cg0BlFaRlmpOtRQIufy2y3zkZMaJQ5kBwHgodcQZTCol%7C21fc4a76a8a48a1988b5664d18c3115b251ad355646ec0b0bbf00b4cd0c0aa34; wp-settings-1=libraryContent%3Dbrowse; wp-settings-time-1=1614070400; __cfduid=d9d479562ae0d9e9a028d749d6594ad101615662603"],"User-Agent":["Mozilla/5.0 (WindowsNT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.82 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Dest":["document"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"udance.com.au"}},"duration":0.000250855,"status":502,"err_id":"x9x62bdu2","err_trace":"reverseproxy.statusError (reverseproxy.go:827)"}
Relevant output from caddy adapt --pretty
"match": [
"host": [
"udance.com.au",
"www.udance.com.au"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"defaults": [
"unknown",
"yes"
"destinations": [
"{backend}",
"{online}"
"handler": "map",
"mappings": [
"input_regexp": "^/tautulli.*",
"outputs": [
"10.1.1.26:8181",
"yes"
"source": "{http.request.uri.path}"
"handle": [
"handler": "authentication",
"providers": {
"http_basic": {
"accounts": [
"password": [REDACTED],
"username": "admin"
"hash": {
"algorithm": "bcrypt"
"hash_cache": {}
"match": [
"path": [
"/phpmyadmin*"
"handle": [
"encodings": {
"gzip": {}
"handler": "encode"
"group": "group9",
"handle": [
"routes": [
"handle": [
"body": "Denied {http.request.uri.path}",
"handler": "static_response",
"status_code": 403
"match": [
"expression": "{backend} == \"unknown\""
"group": "group9",
"handle": [
"routes": [
"handle": [
"headers": {
"Location": [
"https://udance.statuspage.io"
"status_code": 302
"match": [
"expression": "{online} == \"no\""
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"dial": "{http.request.uri.path}"
"dial": "{backend}"
"terminal": true
- Checked the Caddy log.
- Confirmed the regex expression used.
