Handle the default case of map directive differently
I want to have different behavior when a default match happens in the map directive, and I can’t seem to get it to work.
For any other sub-subdomain except for the listed ones, I should get a 404 response, but I’m currently getting a 502, and from the logs it looks like caddy is still trying to reverse proxy for those cases. I don’t quite understand why it’s happening.
"logger":"http.log.error","msg":"dial tcp: lookup dummy on 8.8.8.8:53: no such host"
when trying to access an “invalid” route.
AlmaLinux 9.4 x86_64
systemctl enable --now caddy
Irrelevant.
vps6.dedyn.io, *.vps6.dedyn.io {
                dns desec {
                        token "<token>"
        map {labels.3} {backend} {prt} {
                files localhost 5091
                jellyfin server 80
                music server 80
                default dummy 0
    @invalid `{prt} == 0`
    handle @invalid {
        respond 404
    reverse_proxy {backend}:{prt}
I was trying to use this solution.
I think you have to do == "0"
But it’s weird because it’s meant to take numeric map outputs as numbers, not strings. Hmm.
Oh I see the problem, weird. We do the type conversion for regular map cases, but for the default case we store it as []string in the JSON config. Whoops.
So, for now I need to convert it to string, yes? I hope this will be fixed in the future?
Yeah just do a string comparison.
I haven’t looked into whether we can fix it or not, it might have knock-on effects.
Oh yeah, the other option is you can use the vars matcher instead of an expression matcher
	@invalid vars {prt} 0
	handle @invalid {
		respond 404
Great, thanks for the help. I think the expression matcher makes more semantic sense for me, and I use it in other parts of my Caddyfile as well. So I’ll just stick to that.
