This is not th first time I’ve seen a jws verification error… So now I’m intrigued, but I’ll need more information. How can I set up a server and get the same error you are?
So using unraid and the docker container are required to reproduce the error?
That’s a lot to ask, so if you can simplify it that will speed things up. I won’t have time to go through all those steps – nor do I want to start a trial on some service – so if you can reproduce the error without unraid + docker, that would be helpful. (Basically, you’re on your own unless it can become easier to replicate.)
I recreated the container without a specific container path to the Caddyfile which was in the docker template by default. then i navigated to the /etc/caddy/Caddyfile location and added my configuration to the Caddyfile and it worked fine. only annoying thing is that anytime i want to update the Caddyfile i have to go through the console and then navigate to /etc/caddy/Caddyfile to edit the caddyfile. i’d rather be able to navigate through a GUI and edit with notepad or such.
