Making a forward proxy with v2
1. Caddy version (caddy version): v2.1.1
Via Ubuntu terminal + service
Ubuntu 20
This was my v1 caddyfile.
isotope.dev {
gzip
log /var/log/caddy_access.log
errors /var/log/caddy_error.log
errors {
  403 /var/www/403.html
forwardproxy {
  basic auth bruh 1234
  hide_ip
  hide_via
  response_timeout 30
  dial_timeout 30
  acl {
    allowfile /var/www/allowed.txt
    denyfile /var/www/blocked.txt
I need to use the http.forwardproxy plugin but for Caddy v2. If i cant then i need to find a way to use Caddy v1
Ive tried using other services and they do not work like how it did with v1
The forwardproxy plugin for v2 isn’t ready yet, but it’s a work in progress.
There’s the v2 branch in git here (not sure if it compiles yet):
You can follow this issue for progress:
https://github.com/caddyserver/forwardproxy/issues/72
