Issues reaching a nextcloud instance of different host
Caddy v1.0.3
I am running it in Docker container; this is the run command:
docker run -d\
    --name caddy \
    --restart=always \
    -v /docker/config/caddy/Caddyfile:/etc/Caddyfile \
    -v /docker/config/caddy/log:/etc/log \
    -v /docker/config/caddy/.caddy:/root/.caddy \
    -v /media/daten/WEBSERVICEDATEN/caddy/www/:/srv \
    -p 80:80 \
    -p 443:443 \
    -p 2015:2015 \
    -e ACME_AGREE=true \
    abiosoft/caddy:php
host: ubuntu 18.04
paste command here
paste full file contents here
#FOLDERS
homer-s.my-wan.de {
  root /srv
  tls rudolf123@yahoo.de
  #tls off
  log    /etc/log/gcbilder-access.log
  errors /etc/log/gcbilder-errors.log
  gzip
#COPS AUF FILESERVER
ebooks.broehlis.de {
  proxy / 192.168.100.11:8030
  basicauth / a b
  basicauth / c d
  log    /etc/log/ebooks-access.log
  errors /etc/log/ebooks-errors.log
  gzip
#NEXTCLOUD AUF FILESERVER
nc.broehlis.de, nextcloud.broehlis.de {
  proxy / 192.168.100.11:8020 {
    websocket
  gzip
   # client support (e.g. os x calendar / contacts)
  redir /.well-known/carddav /remote.php/carddav 301
  redir /.well-known/caldav /remote.php/caldav 301
  header / {
    Referrer-Policy "no-referrer"
    Strict-Transport-Security "max-age=31536000; includeSubdomains"
    X-Frame-Options "SAMEORIGIN"
    Referrer-Policy "same-origin"
  log /etc/log/nextcloud-access.log
  errors /etc/log/nextcloud-errors.log
#bitwarden AUF FILESERVER
bw.broehlis.de {
  proxy / 192.168.100.11:8040 {
    insecure_skip_verify
  proxy /notifications/hub 192.168.100.11:3012 {
  websocket
 proxy /notifications/hub/negotiate 192.168.100.11:8040 {
  log    /etc/log/bw-access.log
  errors /etc/log/bw-errors.log
  gzip
#wordpress
broehlis.de {
  proxy / 192.168.100.11:8090 {
  header / {
  log /etc/log/caddy.log
  errors /etc/log/caddy.errors
  gzip
#Syncthing AUF FILESERVER
sync.broehlis.de {
  proxy / http://192.168.100.11:8384 {
  basicauth / a b
  log    /etc/log/sync-access.log
  errors /etc/log/sync-errors.log
  gzip
  timeouts {
  read none
  write none
  header none
#firefox sync server
ffsyncserver.broehlis.de {
    proxy / http://192.168.100.11:5000/token/1.0/sync/1.5 {
#Guacamole Virtualbox
vm.broehlis.de {
  proxy / http://192.168.100.11:8080/guacamole {
      websocket
#NEXTCLOUD AUF RPI Nextcloud
daniel.broehlis.de {
  proxy / https://192.168.100.123:8432 {
    websocket
  gzip
  header / {
  log /etc/log/nextcloud2-access.log
  errors /etc/log/nextcloud2-errors.log
All my Caddyfile is working for month. I added the last chapter ############################################
and I am receiving a 502 Bad Gateway error.
If I am navigating to https://192.168.100.123:8432 manually it is showing me nextcloud …
Actions
2020/12/05 11:08:21 [INFO] Serving http://vm.broehlis.de
2020/12/05 11:08:21 [INFO] Serving http://daniel.broehlis.de
2020/12/05 11:08:21 [WARNING] Sending telemetry (attempt 1): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 11:08:29 [WARNING] Sending telemetry (attempt 2): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 11:08:56 [WARNING] Sending telemetry (attempt 3): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 11:10:00 [ERROR] Sending telemetry: Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host
2020/12/05 11:16:15 http: TLS handshake error from 172.17.0.1:37470: EOF
2020/12/05 11:16:15 http: TLS handshake error from 172.17.0.1:37474: EOF
2020/12/05 11:16:16 http: TLS handshake error from 172.17.0.1:37478: EOF
2020/12/05 11:16:16 http: TLS handshake error from 172.17.0.1:37482: tls: no cipher suite supported by both client and server
2020/12/05 11:16:16 http: TLS handshake error from 172.17.0.1:37486: EOF
2020/12/05 11:16:16 http: TLS handshake error from 172.17.0.1:37490: tls: client offered only unsupported versions: [302 301 300]
2020/12/05 11:16:17 http: TLS handshake error from 172.17.0.1:37494: EOF
2020/12/05 11:16:17 http: TLS handshake error from 172.17.0.1:37498: EOF
2020/12/05 11:16:18 http: TLS handshake error from 172.17.0.1:37502: EOF
2020/12/05 11:16:18 http: TLS handshake error from 172.17.0.1:37506: EOF
2020/12/05 11:20:59 http: TLS handshake error from 172.17.0.1:38498: no certificate available for ‘’
2020/12/05 11:20:59 http: TLS handshake error from 172.17.0.1:38504: no certificate available for ‘82.165.67.61’
2020/12/05 11:21:00 http: TLS handshake error from 172.17.0.1:38508: no certificate available for ‘82.165.67.61’
2020/12/05 11:21:00 http: TLS handshake error from 172.17.0.1:38512: no certificate available for ‘82.165.67.61’
2020/12/05 11:21:00 http: TLS handshake error from 172.17.0.1:38516: no certificate available for ‘82.165.67.61’
2020/12/05 11:21:00 http: TLS handshake error from 172.17.0.1:38520: no certificate available for ‘82.165.67.61’
2020/12/05 11:21:01 http: TLS handshake error from 172.17.0.1:38524: tls: client offered only unsupported versions: [302 301 300]
2020/12/05 11:21:01 http: TLS handshake error from 172.17.0.1:38528: no certificate available for ‘82.165.67.61’
2020/12/05 11:21:01 http: TLS handshake error from 172.17.0.1:38532: no certificate available for ‘82.165.67.61’
2020/12/05 11:21:01 http: TLS handshake error from 172.17.0.1:38536: no certificate available for ‘82.165.67.61’
2020/12/05 11:21:02 http: TLS handshake error from 172.17.0.1:38540: no certificate available for ‘82.165.67.61’
2020/12/05 11:34:24 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 11:59:05 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 12:08:12 [INFO][cache:0xc0000333b0] Scanning for stale OCSP staples
2020/12/05 12:08:12 [INFO][cache:0xc0000333b0] Done checking OCSP staples
2020/12/05 12:10:41 [WARNING] Sending telemetry (attempt 1): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 12:10:49 [WARNING] Sending telemetry (attempt 2): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 12:11:16 [WARNING] Sending telemetry (attempt 3): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 12:12:20 [ERROR] Sending telemetry: Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host
2020/12/05 12:53:40 [INFO] 127.0.0.1 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 13:08:12 [INFO][cache:0xc0000333b0] Scanning for stale OCSP staples
2020/12/05 13:08:12 [INFO][cache:0xc0000333b0] Done checking OCSP staples
2020/12/05 13:13:02 [WARNING] Sending telemetry (attempt 1): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 13:13:10 [WARNING] Sending telemetry (attempt 2): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 13:13:37 [WARNING] Sending telemetry (attempt 3): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 13:14:41 [ERROR] Sending telemetry: Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host
2020/12/05 13:16:52 [INFO] 192.168.100.11 - No such site at :80 (Remote: 192.168.100.190, Referer: )
2020/12/05 13:16:52 [INFO] 192.168.100.11 - No such site at :80 (Remote: 192.168.100.190, Referer: http://192.168.100.11/)
2020/12/05 13:26:37 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 13:33:06 [ERROR] failed to copy buffer: context canceled
2020/12/05 13:33:29 [INFO] 127.0.0.1 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 13:41:55 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 14:08:12 [INFO][cache:0xc0000333b0] Scanning for stale OCSP staples
2020/12/05 14:08:12 [INFO][cache:0xc0000333b0] Done checking OCSP staples
2020/12/05 14:14:51 [WARNING] Sending telemetry (attempt 1): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 14:14:59 [WARNING] Sending telemetry (attempt 2): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 14:15:26 [WARNING] Sending telemetry (attempt 3): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 14:16:30 [ERROR] Sending telemetry: Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host
2020/12/05 14:38:06 http: TLS handshake error from 172.17.0.1:51286: no certificate available for ‘netdata.homer-s.my-wan.de
2020/12/05 14:58:34 http: TLS handshake error from 172.17.0.1:55398: EOF
2020/12/05 15:08:12 [INFO][cache:0xc0000333b0] Scanning for stale OCSP staples
2020/12/05 15:08:12 [INFO][cache:0xc0000333b0] Done checking OCSP staples
2020/12/05 15:17:26 [WARNING] Sending telemetry (attempt 1): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 15:17:34 [WARNING] Sending telemetry (attempt 2): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 15:18:01 [WARNING] Sending telemetry (attempt 3): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 15:19:05 [ERROR] Sending telemetry: Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host
2020/12/05 15:23:27 http: TLS handshake error from 172.17.0.1:60044: EOF
2020/12/05 15:43:45 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: http://82.165.67.61:80/admin/login.asp)
2020/12/05 15:48:51 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 16:08:12 [INFO][cache:0xc0000333b0] Scanning for stale OCSP staples
2020/12/05 16:08:12 [INFO][cache:0xc0000333b0] Done checking OCSP staples
2020/12/05 16:18:47 [INFO] 127.0.0.1 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 16:19:17 [WARNING] Sending telemetry (attempt 1): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 16:19:25 [WARNING] Sending telemetry (attempt 2): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 16:19:52 [WARNING] Sending telemetry (attempt 3): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 16:20:56 [ERROR] Sending telemetry: Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host
2020/12/05 16:30:49 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: http://82.165.67.61:80/admin/login.asp)
2020/12/05 16:46:27 [INFO] - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 16:53:19 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 16:53:20 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 16:53:21 [INFO] 82.165.67.61 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 17:08:12 [INFO][cache:0xc0000333b0] Scanning for stale OCSP staples
2020/12/05 17:08:12 [INFO][cache:0xc0000333b0] Done checking OCSP staples
2020/12/05 17:18:33 http: TLS handshake error from 172.17.0.1:56262: EOF
2020/12/05 17:18:34 http: TLS handshake error from 172.17.0.1:56266: tls: unsupported SSLv2 handshake received
2020/12/05 17:18:34 http: TLS handshake error from 172.17.0.1:56270: tls: client offered only unsupported versions: [300]
2020/12/05 17:18:34 http: TLS handshake error from 172.17.0.1:56274: tls: client offered only unsupported versions: [301 300]
2020/12/05 17:18:35 http: TLS handshake error from 172.17.0.1:56278: tls: client offered only unsupported versions: [302 301 300]
2020/12/05 17:18:35 http: TLS handshake error from 172.17.0.1:56284: no certificate available for ‘82.165.67.61’
2020/12/05 17:18:35 http: TLS handshake error from 172.17.0.1:56288: no certificate available for ‘82.165.67.61’
2020/12/05 17:21:58 [WARNING] Sending telemetry (attempt 1): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: read udp 172.17.0.12:57644->192.168.100.1:53: i/o timeout - backing off and retrying
2020/12/05 17:22:06 [WARNING] Sending telemetry (attempt 2): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 17:22:33 [WARNING] Sending telemetry (attempt 3): Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host - backing off and retrying
2020/12/05 17:23:37 [ERROR] Sending telemetry: Post https://telemetry.caddyserver.com/v1/update/88acc80c-e433-44d7-a260-c1069ebf2bb2: dial tcp: lookup telemetry.caddyserver.com on 192.168.100.1:53: no such host
2020/12/05 17:23:39 [INFO] 127.0.0.1 - No such site at :80 (Remote: 172.17.0.1, Referer: )
2020/12/05 17:35:23 http2: received GOAWAY [FrameHeader GOAWAY len=8], starting graceful shutdown
2020/12/05 17:57:01 [INFO] 127.0.0.1 - No such site at :80 (Remote: 172.17.0.1, Referer: )
I am completly desperate
Thanks for your help.
Caddy v1 is EOL and no longer supported, please upgrade to Caddy v2!
Here’s a guide for nextcloud in Caddy v2:
We have an official Docker image for v2: Docker
I tried to setup a container without success and big issues. I guess I would need much easier/detailed instructions.
Maybe a good hint on current issue anyway?
I just linked all the relevant documentation for you to review. I’m not sure how it could be made any clearer.
Do not take it personally, I am sure it is my lack of knowledge.
After setting up a caddy2 container on a fresh VM I am not able to reach the basic site on the server (service is active) …
So you may have an idea about my skeptic of loosing access to my webs services
@francislavoie
I started a new container v2 and tried to convert step by step my old Caddyfile but with the first one I am already struggling.
I can access the site but if I am adding the auth name and pass it is looping in the request for login data???
  reverse_proxy 192.168.100.11:8030
  basicauth /* {
     gast JDJhJDEwJDNSNURGeWo2cDI5TEtFZVI1YkZLYnVmYWduYnhhSmdvQXpieXNDTXhzYjRuazVnM1pmaTNt
  basicauth /* {
    marie  JDJhJDEwJDdTeDJOcGhBaFF3VEIwcHZNUzJjVXVvMUl4eDlTUnpTNllmcnlJTk0wdTNzRHA3Y3E1Qklt
       output file  /data/log/ebooks.log
Combine your basicauth, don’t use it twice:
	basicauth {
@francislavoie I am procceeding well. A lot of revers-proxy chapters are already working. As usually I saved the “big ones” for the final. I found no sample about Bitwarden.
This was my v1 Caddyfile:
bw.broehlis.de {
  websocket
  gzip
  tls erwin12344321@yahoo.de
I converted it to this, which at least has no error message in Caddy log but is not directing to bw server:
bw.broehlis.de {
  reverse_proxy  192.168.100.11:8040 {
           tls_insecure_skip_verify
  reverse_proxy /notifications/hub 192.168.100.11:3012 {
#  websocket
  reverse_proxy /notifications/hub/negotiate 192.168.100.11:8040
       output file  /data/log/bw.log
Maybe you have some idea how to adapt better …
Did I already mention that I am really appreciating your help!!!
Another one (the last one) which leads us back to initial issue of this threat, also.
#NEXTCLOUD AUF RPi
dany.broehlis.de {
  reverse_proxy  192.168.100.123:443
       output file  /data/log/nextcloud-daniel.log
I am receiving this error message
grafik
But this is working
https:/192.168.100.123:443
You may need to add * to the end of the path matcher. Caddy v2 uses exact path matching, so for example this will not match /notifications/hub/negotiate/foo, unless you change it to /notifications/hub/negotiate*.
Also, I would reorder them in your Caddyfile, in the order of the path matcher length, just for readability’s sake. The Caddyfile adapter has sorting logic anyways to try and guess which matchers are more specific (longer path is more specific, so /notifications/hub/negotiate* should be tried before /notifications/hub*, because they overlap and you would have one “hide” the other if they were not sorted.
I don’t think Caddy knows that it must connect over tls here, so that might be the issue you’re running into. Either specify https:// on the proxy address, or add tls to the transport options (https:// is a shortcut for specifying tls, either would do).
I’m not sure, but you may need to do the same for your negotiate one.
Caddy v2 no longer needs websocket specified, it’s always on by default (Caddy passes through all headers transparently):
Re the nextcloud one, same thing as above, need https:// or tls specified to connect over TLS.
Is transport really a directive for Caddyfile?
Thats the way I tried it ending in a error message and not starting of caddy:
#NEXTCLOUD AUF RPi
dany.broehlis.de {
Referrer-Policy “no-referrer”
Strict-Transport-Security “max-age=31536000; includeSubdomains”
X-XSS-Protection “1; mode=block”
X-Content-Type-Options “nosniff”
X-Frame-Options “SAMEORIGIN”
Referrer-Policy “same-origin”
I found after deleting transport again this error.
“logger”:“http”,“msg”:“server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS”,“server_name”:“srv0”,“https_port”:443}
How can I handle the reverse proxying to a different host in this case 192.168.100.123; can it be that there is a lack of kowledge about where to look for a TLS cer?
transport is a subdirective of reverse_proxy:
Please remember to use ``` on the lines before and after your config to use code formatting!
This helped
reverse_proxy 192.168.100.123:443 {
For a testing setup … ok
all other tests were without success
Thanks SO much!!!
My migration from v1 to v2 wasn’t as hard as expected!!!
