I installed it from the AUR and caddy version
only says (devel)
, but the package is versioned 2.0.0-2
, last updated 2020-05-15.
systemd
- the AUR package provides a service file.
Arch Linux, last updated today.
sudo systemctl start caddy
Description=Caddy Web Server
After=network.target
User=http
Group=http
ExecStart=/usr/bin/caddy run --config /etc/caddy/Caddyfile --resume --environ
ExecStop=/usr/bin/caddy stop
# Hardening options
ProtectSystem=strict
PrivateDevices=true
ProtectHome=true
ReadWritePaths=/var/lib/caddy /var/log/caddy /srv/http
ReadOnlyPaths=/data
NoNewPrivileges=true
ProtectKernelTunables=true
ProtectKernelModules=true
ProtectControlGroups=true
LockPersonality=true
(common) {
encode zstd gzip
tls [EMAIL REDACTED]
header * {
Strict-Transport-Security "max-age=17280000"
Server "Apache/2.4.9 (Emacs/GNU/Hurd 0.6)"
@mp4 { path *.mp4 }
header @mp4 Content-Type video/mp4
@bin { path *.bin }
header @bin Content-Type application/octet-stream
notes.[DOMAIN REDACTED] {
level DEBUG
import common
root * /data/files/dokuwiki
php_fastcgi /var/run/php-fpm/php-fpm.sock
@forbidden {
path /data/* /conf/* /inc/* /vendor/* /install.php
respond @forbidden 403 {
body "No."
close
@media {
path_regexp media "/_media/(.*)"
rewrite @media /lib/exe/fetch.php?media={http.regexp.media.1}
@detail {
path_regexp detail "/_detail/(.*)"
rewrite @detail /lib/exe/detail.php?media={http.regexp.detail.1}
@export {
path_regexp export "/_export/([^/]+)/(.*)"
rewrite @export /doku.php?do=export_{http.regexp.export.1}&id={http.regexp.export.2}
@regular {
not path /lib/*
path_regexp regular "/(.*)"
rewrite @regular /doku.php?id={http.regexp.regular.1}&{query}
I previously had a dokuwiki install using PHP-FPM behind caddy (along with some other services) using the example configuration linked below (modified slightly for my environment). I upgraded to caddy v2 today due to an unrelated issue with websockets (not resolved, still trying to figure it out).
I’ve attempted to port this configuration file to v2, but am not sure how to do it, as v2 seems pretty different and I don’t really understand how to translate things. My attempt at it so far is shown above, and it loads without errors, but for all URLs I’ve tried it produces responses like this in curl:
HTTP/2 200
referrer-policy: strict-origin-when-cross-origin
server: Apache/2.4.9 (Emacs/GNU/Hurd 0.6)
strict-transport-security: max-age=17280000
x-content-type-options: nosniff
date: Sat, 06 Jun 2020 17:49:22 GMT
and is a blank screen in the browser. I’m not sure why this is, or how/if there’s any way to debug it.
HTTP requests produce blank output as shown above. There are no errors on (re)load. Here’s a log line from caddy produced when I try it:
{"level":"info","ts":1591467089.5940807,"logger":"http.log.access.log0","msg":"handled request","request":{"method":"GET","uri":"/_media/","proto":"HTTP/2.0","remote_addr":"[REDACTED]:37076","host":"notes.[REDACTED]","headers":{"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"],"Accept-Language":["en-US,en;q=0.5"],"Accept-Encoding":["gzip, deflate, br"],"Dnt":["1"],"Pragma":["no-cache"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:77.0) Gecko/20100101 Firefox/77.0"],"Cookie":["[REDACTED]"],"Upgrade-Insecure-Requests":["1"],"Cache-Control":["no-cache"]},"tls":{"resumed":false,"version":772,"ciphersuite":4865,"proto":"h2","proto_mutual":true,"server_name":"notes.[REDACTED]"}},"common_log":"[REDACTED] - - [06/Jun/2020:18:11:29 +0000] \"GET /_media/ HTTP/2.0\" 0 0","duration":0.000149868,"size":0,"status":0,"resp_headers":{"Server":["Apache/2.4.9 (Emacs/GNU/Hurd 0.6)"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Strict-Transport-Security":["max-age=17280000"],"X-Content-Type-Options":["nosniff"]}}
I’ve tried making some changes to the config there, but don’t know how to make it work correctly. I may just have to temporarily reverse proxy to a nginx instance instead, since dokuwiki has configuration for this documented.
