1. Output of caddy version:
v2.6.2
On an Arch Linux image on vultr! Using php-fpm7, no docker
sudo caddy reload --config /etc/caddy/Caddyfile
website.com {
encode gzip zstd
root * /home/a/website/wiki
#Remember to comment the below forbidden block out when you're installing, and uncomment it when done.
#@forbidden path /data/* /conf/* /bin/* /inc/* /install.php
#handle @forbidden {
# respond * 403
#End of the forbidden block
try_files {path} {path}/index.html
route {
handle_path /_media/* {
rewrite * /lib/exe/fetch.php?media={path}&{query}
handle_path /_detail/* {
rewrite * /lib/exe/detail.php?media={path}&{query}
handle /_export/* {
@export path_regexp export ^/_export/([^/]+)/(.*)
rewrite @export /doku.php?do=export_{re.export.1}&{query}&id={re.export.2}
handle / {
rewrite * /doku.php?{query}
try_files {path} /doku.php?id={path}&{query}
php_fastcgi unix//run/php-fpm7/php-fpm.sock
# don't ask but I also need to expose a file on a very specific URL
http://www.mywebsite.com {
root * /var/www/test
3. The problem Iām having:
Currently Iām just trying to get my wiki to work, then eventually push it under the path of /wiki.
I get: File not found. when I visit the website.
I followed this config file as a baseline:
https://www.dokuwiki.org/install:caddy
I have tried commenting and uncommenting the selected blocks
and I also tried messing around with file permissions:
but still no luck!
I tried: Issues porting v1 dokuwiki config to v2 - #4 by matt
Changing unix// to unix/ which gives me a 502 instead opposed to 404
