How to ipv6 together with Nginx?
I try to run latest Caddy under debian linux.
I have one ipv4 and some ipv6. Nginx is running on ports 80 and 443 on the ipv4.
How do I configure Caddy to listen to ports 80 and 443 only on one specific ipv6?
Hi :wave:
With the release of caddy v2.5.0 (less than 1 hour ago) you can specify default_bind tcp6/[::] as global option in your Caddyfile.
See Global options (Caddyfile) — Caddy Documentation and Conventions — Caddy Documentation
And maybe the underlying net package - net - pkg.go.dev, because tcp4/0.0.0.0 and tcp6/[::] are not mentioned in the docs (yet).
localhost {
    respond "localhost"
*.localhost {
    respond "_wildcard.localhost"
Alternatively, you would need to add bind tcp6/[::] to each of your vhosts:
localhost {
    bind tcp6/[::]
    respond "localhost"
*.localhost {
    bind tcp6/[::]
bind (Caddyfile directive) — Caddy Documentation will work just fine if you are below v2.5.0.
Because I first want to test Caddy before I (perhaps) migrate from Nginx.
I updated to 2.5.0 and the bind now works. thanks!
