We are using caddy as reverse proxy to our backend(s). But surprisingly at about 10-15 requests/s caddy uses more CPU than the actual application - which has me worried for scaling up.
I would like to find the bottlenecks but don’t quite know how to start best.
Is go profiling the next step - or are there other things to look into first?
No error message or any significant log output. Verbosity is set to ERROR.
caddy:2.10.0-alpine
apiVersion: v1
kind: ConfigMap
metadata:
namespace: infra
labels:
app: caddy
data:
Caddyfile: | see 4d)
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: infra
labels:
app: caddy
annotations:
reloader.stakater.com/auto: "true"
spec:
replicas: 1
selector:
matchLabels:
app: caddy
template:
metadata:
labels:
app: caddy
annotations:
prometheus.io/scrape: "true"
prometheus.io/port: "2019"
prometheus.io/path: "/metrics"
spec:
containers:
- name: caddy
image: caddy:2.10.0-alpine
- name: http
containerPort: 80
- name: https
containerPort: 443
- name: admin
containerPort: 2019
env:
- name: MAINTENANCE_LIVE
valueFrom:
secretKeyRef:
key: live
- name: MAINTENANCE_TEST
valueFrom:
secretKeyRef:
key: test
volumeMounts:
- name: caddy-config
mountPath: /etc/caddy
- name: caddy-data
mountPath: /data
livenessProbe:
initialDelaySeconds: 2
httpGet:
path: /metrics
port: admin
readinessProbe:
httpGet:
path: /metrics
port: admin
securityContext:
allowPrivilegeEscalation: false
runAsUser: 65534
runAsGroup: 65534
resources:
requests:
memory: 100Mi
limits:
memory: 300Mi
configMap:
- name: caddy-data
persistentVolumeClaim:
claimName: caddy-data-volume-claim
k3s (v1.32.7+k3s1) on nixOS
uname -a
Linux blue-c-1 6.12.19-hardened1 #1-NixOS SMP PREEMPT_DYNAMIC Thu Mar 13 12:02:20 UTC 2025 x86_64 GNU/Linux
see 4)
. Service/unit/compose file:
see 4)
email "tcurdt@redacted.org"
admin :2019
metrics
www.redacted.com {
redir https://redacted.com{uri} permanent
redacted.com {
header -server
header /robots.txt cache-control "public, max-age=86400" # 1 day
header /sitemap.xml cache-control "public, max-age=86400" # 1 day
header /manifest.json cache-control "public, max-age=86400" # 1 day
header /favicon.png cache-control "public, max-age=604800" # 1 week
header /img/* cache-control "public, max-age=604800" # 1 week
header /p/script.js cache-control "public, max-age=604800" # 1 week
header /fonts/* cache-control "public, max-age=2592000" # 1 month
# no caching
header /service-worker.js cache-control "no-cache"
header /sw.js cache-control "no-cache"
header /_app/version.* cache-control "no-cache"
header /api/* cache-control "no-cache"
header /webhooks/* cache-control "no-cache"
header /sentry/* cache-control "no-cache"
# immutables
header /_app/immutable cache-control "public, max-age=2592000, immutable"
header /assets/* cache-control "public, max-age=2592000, immutable"
header /audio/* cache-control "public, max-age=2592000, immutable"
referrer-policy "same-origin"
content-security-policy "default-src 'self'; img-src 'self' blob: ; script-src 'self' 'unsafe-inline'; style-src 'self' 'unsafe-inline'; worker-src 'self' blob: ; connect-src 'self'"
access-control-allow-origin https://redacted.com
access-control-allow-methods GET, OPTIONS, HEAD
x-content-type-options nosniff
x-frame-options deny
x-permitted-cross-domain-policies none
cross-origin-embedder-policy require-corp
cross-origin-opener-policy same-origin
cross-origin-resource-policy cross-origin
permissions-policy "geolocation=(), microphone=(), camera=()" # disable browser APIs
@maintenance {
expression {env.MAINTENANCE_LIVE} != ""
handle @maintenance {
respond "{env.MAINTENANCE_LIVE:We will be back shortly}" 503 {
close
@plausible path /p/script.js /p/e
handle @plausible {
rewrite /p/script.js /js/script.js
rewrite /p/e /api/event
reverse_proxy https://plausible.io {
handle /ws/* {
header Access-Control-Allow-Origin "https://redacted.com"
reverse_proxy backend.live.svc.cluster.local:3001 {
lb_try_duration 5s
fail_duration 5s
reverse_proxy backend.live.svc.cluster.local:3000 {
lb_try_duration 5s
fail_duration 5s
old.redacted.com {
header -server
handle /feedback* {
rewrite * /old{uri}
reverse_proxy backend.test.svc.cluster.local:3000 {
lb_try_duration 5s
fail_duration 5s
respond 404
