CPU and memory usage are very high
CPU and memory usage are very high. I only have a few dozen requests per second,
and caddy consumes several GB of memory (1.5 on average, with peaks at 5GB). The CPU is constantly being used at 100% …
I’ve been using the souin cache with Badger since upgrading to 2.8.4 (due to a problem with redis).
But is that enough to explain such high cache consumption? Especially with so few requests, and a cache ttl of 300s?
Do you have an avenue to explore? I admit I have no ideas, and everything seems to be working fine. Except that performance-wise, it’s complicated to maintain.
I put 2 pprof links at the end of the post, one with the CPU profile, the other with the memory.
It seems to be “regexp.(*Regexp).MatchString” that consumes 80%+ of the CPU, but I don’t know more about it :/.
If you need more information, don’t hesitate :slight_smile:
No particular error message, apart from “aborting with incomplete response”, “context cancelled”, …
The host machine runs Debian GNU/Linux 12
Caddy is launched in a docker container, via docker compose.
docker compose
    build: docker/caddy
    env_file:
      - caddy.env
      - "2019:2019"
      - "443:443/udp"
      - ./data:/data
      - ./certs:/certs
      - ./config:/config
      - stg-proxy
  stg-proxy:
    enable_ipv6: true
    ipam:
      config:
        - subnet: fd00::/8
FROM caddy:2.8.4-builder AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/ovh \
    --with github.com/caddyserver/cache-handler
FROM caddy:2.8.4
    order cache before rewrite
    cache {
        api {
            souin
    email alexandre@xxx.fr
    on_demand_tls {
        ask      http://php:80/api/domains/check
        output stderr
        format json
        level ERROR
    servers {
        metrics
(generic_reverse_proxy) {
    @backendRoutes `{path}.startsWith("/api") || {path}.startsWith("/dashboard") || {path}.startsWith("/bundles") || {path}.startsWith("/medias")`
    encode {
        gzip
        zstd
    handle @backendRoutes  {
        cache {
            ttl 300s
        reverse_proxy php:80
    reverse_proxy nextjs:3000
redirect-domain.fr {
    reverse_proxy php-mob-redirect:80
specific-domain.xxx.fr {
    tls /certs/custom-cert.crt /certs/custom-server-key.key
    import generic_reverse_proxy
main-domain.fr {
    redir https://www.{host}{uri}
*.main-domain.fr {
        dns ovh {
            endpoint {$OVH_ENDPOINT}
            application_key {$OVH_APPLICATION_KEY}
            application_secret {$OVH_APPLICATION_SECRET}
            consumer_key {$OVH_CONSUMER_KEY}
https:// {
        on_demand
http://caddy {
    @denied not client_ip private_ranges
    abort @denied
    @metricspath `{path}.startsWith("/metrics")`
    metrics @metricspath
    reverse_proxy /debug/pprof/* localhost:2019 {
    @souinapi `{path}.startsWith("/souin-api")`
    cache @souinapi {
pprof profile : https://pprof.me/63b93d119756840c8435a5cfa220f44e
(svg link)
pprof heap : Pprof.me
(svg link)
/cc @darkweak
