How do I reverse-proxy to diffirent docker containers
1. Output of caddy version:
I use docker image caddy:2
Ubuntu server 22.04
Docker 20.10.12
docker run --rm --netowrk host caddy
Dockerfile
FROM caddy:2
WORKDIR /app
COPY Caddyfile .
CMD ["caddy", "run"]
allure.myproject.dev {
    handle_path /14 {
        rewrite /14 /latest-report
        reverse_proxy :5058
    handle_path /13 {
        rewrite /13 /latest-report
        reverse_proxy :5056
I have 10 docker containers with allure-report. For example i use only two.
I need to proxy requests to specific ports, depending on the transmitted URI
For example:
GET allure.myproject.dev/14 → :5058/latest-report
GET allure.myproject.dev/13 → :5056/latest-report
But config in my Caddyfile dont work as i want. When i make request, i see blank page in response and status code 200. But when i change config to below, i see what i need (I make request on allure.myproject.dev/latest-report)
        reverse_proxy :5058
what should i do in my case? Cant find information.
I tried next configurations:
(dont work)
    handle_path /14 {
        reverse_proxy :5058/latest-report
(dont work, i see blank page)
   handle_path /14 {
        reverse_proxy :5058
Remove this from your Dockerfile. The default command is ideal.
You should copy this to /etc/caddy/Caddyfile instead, which is what the default command uses.
Path matching is exact in Caddy. This means that only the path /14 will match, and nothing else. If you mean to proxy everything under that subpath, then use /14* instead.
Since handle_path strips the path prefix before continuing (the handle directive doesn’t strip the path), the path no longer is /14 at this point. So instead, you should do rewrite * /latest-report if you want to rewrite every request that reaches this handle.
Thanks for help.
I tried edit my Caddyfile to
     handle_path /14 {
          reverse_proxy 127.0.0.1:5058
And it works, but when i added second docker-container in Caddyfile, I see blank page again.
What does the Caddyfile look like after this edit?
What URL are you trying to access after this edit that gives you a blank page?
Caddyfile
    handle_path /14 {
        reverse_proxy :5058
    handle_path /13 {
        reverse_proxy :5056
I trying https://allure.myproject.dev/13, https://allure.myproject.dev/14
UPD.
i need to reverse-proxy requests from allure.myproject.dev/13 to 127.0.0.1:5056/latest-report and allure.myproject.dev/14 to 127.0.0.1:5058/latest-report
