I have a series of docker containers set up on my Synology NAS (using Synology’s Reverse Proxy tool), and I’m trying to replace that with Caddy. The other containers are currently running and accessible over <container_name>.<my_domain>.synology.me:444. For example, I have Beszel accessible at https://beszel.cherringshaw.synology.me:444, and I’m trying to use Caddy to make it accessible at https://beszel.cherringshaw.synology.me.
I use Synology’s DDNS to manage my domain name, and I have port forwarding rules in my local router for 443 and 444 to go my NAS’ local address (192.168.50.4). I’ve also made sure that Synology’s default nginx is no longer listening on port 443 by following: https://www.simplehomelab.com/free-ports-80-and-443-on-synology/
I’m having a hard time finding logs for exactly what’s going wrong - I’m not great with networking or proxies in general, and I’ve sorta muddled my way through to this point by reading forum posts and googling the errors in the logs. But the only logs I can see now just say “connection refused,” with no other indication of what might be going wrong.
Thanks in advance for any help!
When I run
curl -vL https://beszel.cherringshaw.synology.me
I get this output in the terminal:
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
> GET / HTTP/2
> Host: beszel.cherringshaw.synology.me
> user-agent: curl/7.86.0
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Wed, 12 Mar 2025 14:08:23 GMT
and this entry in the docker logs for Caddy:
{"level":"error","ts":1741788307.5427284,"logger":"http.log.error","msg":"dial tcp 192.168.160.3:80: connect: connection refused","request":{"remote_ip":"192.168.160.1","remote_port":"33064","client_ip":"192.168.160.1","proto":"HTTP/2.0","method":"GET","host":"beszel.cherringshaw.synology.me","uri":"/","headers":{"User-Agent":["curl/7.86.0"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"beszel.cherringshaw.synology.me"}},"duration":0.000590436,"status":502,"err_id":"8643f24m3","err_trace":"reverseproxy.statusError (reverseproxy.go:1373)"}
With curl -vL https://beszel.cherringshaw.synology.me:444 (which uses Synology’s Reverse Proxy), I get a successful result with the page contents:
[cam@SynologyNAS caddy (master) ]$ curl -vL https://beszel.cherringshaw.synology.me:444
> GET / HTTP/2
> Host: beszel.cherringshaw.synology.me:444
> accept: */*
< HTTP/2 200
< date: Wed, 12 Mar 2025 14:33:57 GMT
< content-length: 551
< vary: Origin
< x-frame-options: SAMEORIGIN
< x-xss-protection: 1; mode=block
< strict-transport-security: max-age=15768000; includeSubdomains; preload
<!doctype html>
<html lang="en" dir="ltr">
<head>
<meta charset="UTF-8" />
<link rel="manifest" href="/static/manifest.json" />
<link rel="icon" type="image/svg+xml" href="/static/favicon.svg" />
<meta name="viewport" content="width=device-width, initial-scale=1.0" />
<title>Beszel</title>
<script>window.BASE_PATH = "/"</script>
<script type="module" crossorigin src="/assets/index-aVukMUSG.js"></script>
<link rel="stylesheet" crossorigin href="/assets/index-Sz60ABYj.css">
</head>
<body>
<div id="app"></div>
</body>
</html>
curl -vL http://192.168.50.4:8090 also succeeds and shows the page contetnts.
3. Caddy version: 2.9.1
Synology NAS (some flavor of Linux), with Caddy running via docker-compose.
sudo docker-compose docker-compose.yml up --force-recreate -d
image: caddy:2.9.1
- "443:443/udp"
- caddy_data:/data
- caddy_config:/config
- nas_docker_compose_default
caddy_data:
caddy_config:
nas_docker_compose_default:
external: true
My other container is on the same docker network:
beszel:
image: henrygd/beszel
container_name: beszel
extra_hosts:
- host.docker.internal:host-gateway
- ./beszel_data:/beszel_data
beszel-agent:
image: "henrygd/beszel-agent"
container_name: "beszel-agent"
network_mode: host
# monitor other disks / partitions by mounting a folder in /extra-filesystems
# - /mnt/disk/.beszel:/extra-filesystems/sda1:ro
KEY: "REDACTED"
PORT: 45876
external: true
And I’ve verified this with docker network inspect:
[cam@SynologyNAS caddy (master) ]$ sudo docker network inspect nas_docker_compose_default
"Name": "nas_docker_compose_default",
"Id": "d2e55f7d818b0f8d4f5418a839dbff1e8c327a28ae49a66e3399cf72348653bf",
"Created": "2025-02-28T06:08:04.094188572-06:00",
"Scope": "local",
"Driver": "bridge",
"EnableIPv6": false,
"IPAM": {
"Driver": "default",
"Options": null,
"Config": [
"Subnet": "192.168.160.0/20",
"Gateway": "192.168.160.1"
"Internal": false,
"Attachable": false,
"Ingress": false,
"ConfigFrom": {
"Network": ""
"ConfigOnly": false,
"Containers": {
"b5a30bcb29caf732ede2e31bf2a7dcad51ac2709db739552464f1411d34ea93b": {
"Name": "caddy-caddy-1",
"EndpointID": "e970ad5dff1ec2b34f9b356e102660ed0ac587383a512c96351f4a9f5de8d22a",
"MacAddress": "02:42:c0:a8:a0:02",
"IPv4Address": "192.168.160.2/20",
"IPv6Address": ""
"d3a7478d9d2e50cf246b22883faf18a6046fdebf2db7f1cd61ae5da173fc0a7d": {
"Name": "beszel",
"EndpointID": "224eab30c9159345b2cf5f2fd5494ad924c2b3ddaeb3d55270a022c65a204d1a",
"MacAddress": "02:42:c0:a8:a0:03",
"IPv4Address": "192.168.160.3/20",
"IPv6Address": ""
"Options": {},
"Labels": {
"com.docker.compose.network": "default",
"com.docker.compose.project": "nas_docker_compose",
"com.docker.compose.version": "2.9.0"
caddy.cherringshaw.synology.me {
respond "Hello, world!"
beszel.cherringshaw.synology.me {
reverse_proxy http://beszel:8090
localhost {
respond "Hi there"
I’ve also tried the following variations, with similar results:
reverse_proxy beszel
reverse_proxy beszel:8090
Referenced this post to get to where I currently am: How do I reverse-proxy to diffirent docker containers
