ubuntu 18.04
systemd
baremetal
Caddy installed package from deb repo
systemctl start caddy
Type=notify
(log) {
output file {args.0} {
roll_size 100MiB
level DEBUG
format json
format filter {
wrap json
fields {
common_log delete
resp_headers>Content-Security-Policy delete
request>remote_addr ip_mask {
ipv4 24
ipv6 32
#Bind admin endpoint on all interfaces
admin 0.0.0.0:2019
on_demand_tls {
ask http://localhost:8000/api/cname/validate
# Workaround to prevent on_demand being enabled on all domains
# see https://github.com/caddyserver/caddy/pull/4128
email security+caddy@lempire.co
import log /var/log/caddy/default_req.log
# Reduce caddy reload grace_period to 3 min (default was 20 min) to improve reload
# See https://caddy.community/t/hangs-on-reload/12010/35
# Because of websockets long cnx, reload always took grace_period duration
grace_period 3m
# Redirect any accesses using an IP instead of a domain name
# hackerone report: https://hackerone.com/reports/723126
51.91.128.49:80,
91.121.37.140:80,
147.135.229.201:80,
51.254.243.65:80,
54.36.18.249:80,
46.105.54.36:80
redir https://app.lemlist.com{uri}
(cloudflare_matchers) {
remote_ip 103.21.244.0/22
remote_ip 103.22.200.0/22
remote_ip 103.31.4.0/22
remote_ip 104.16.0.0/13
remote_ip 104.24.0.0/14
remote_ip 108.162.192.0/18
remote_ip 131.0.72.0/22
remote_ip 141.101.64.0/18
remote_ip 162.158.0.0/15
remote_ip 172.64.0.0/13
remote_ip 173.245.48.0/20
remote_ip 188.114.96.0/20
remote_ip 190.93.240.0/20
remote_ip 197.234.240.0/22
remote_ip 198.41.128.0/17
remote_ip 2400:cb00::/32
remote_ip 2606:4700::/32
remote_ip 2803:f800::/32
remote_ip 2405:b500::/32
remote_ip 2405:8100::/32
remote_ip 2a06:98c0::/29
remote_ip 2c0f:f248::/32
(front_servers) {
to localhost:42001
to localhost:42002
to localhost:42003
to localhost:42004
to localhost:42005
to localhost:42006
to localhost:42007
to localhost:42008
health_uri /api/ping
health_interval 1s
health_timeout 5s
(badbots_filter) {
@badbots {
header_regexp User-Agent "(?i)Fuzz Faster U Fool.*"
header @badbots {
X-Cache-Debug "bbf"
Server ""
respond @badbots "Access denied" 403
# Main application
app.lemlist.com,
app2.lemlist.com
import log /var/log/caddy/front_req.log
# route keyword is mandatory to force Caddy to keep our
# directives order instead of using the Caddy builtin order
route {
request_body {
max_size 20MB
@from_cloudflare {
import cloudflare_matchers
@not_from_cloudflare {
not {
# pass all api lempire (e, i) requests to one
# dedicated Meteor app process
@api_e_i {
path /api/lempire/*
header @api_e_i {
X-Cache-Debug "app.api_e_i"
Server ""
reverse_proxy @api_e_i {
to localhost:8000
# pass all api requests to Meteor api process
@api {
path /api/*
header @api {
X-Cache-Debug "app.api"
Server ""
reverse_proxy @api {
to localhost:42100
# Caches
# must be after /api routes or https://app.lemlist.com/api/froala/files/*.jpg will not be served by meteor
@cache_app {
path *.svg *.woff2 *.eot *.ttf *.woff *.jpg *.jpeg *.png *.gif *.ico *.html
header @cache_app {
# 1d expiration
Cache-Control max-age=86400
X-Cache-Debug "app.cache"
Server ""
file_server @cache_app {
root /opt/lemlist/app/programs/web.browser/app
@cache_app2 {
path_regexp ^/lib/.*\.(map|js|css)$
header @cache_app2 {
# 1d expiration
X-Cache-Debug "app.cache2"
Server ""
file_server @cache_app2 {
@cache_version {
path_regexp ^/[0-9a-z]+\.(js|css|map).*
header @cache_version {
# 1d expiration
X-Cache-Debug "app.cache_version"
Server ""
file_server @cache_version {
root /opt/lemlist/web.browser
# Anything else goes to Meteor fronts
header @from_cloudflare {
X-Cache-Debug "app.main.cf"
Server ""
reverse_proxy @from_cloudflare {
header_up X-Real-IP {http.request.header.CF-Connecting-IP}
header_up X-Forwarded-For {http.request.header.CF-Connecting-IP}
header_up Lb-Hash {http.request.header.CF-Connecting-IP}:{remote_port}
import front_servers
lb_policy header CF-Connecting-IP
header @not_from_cloudflare {
X-Cache-Debug "app.main"
Server ""
reverse_proxy @not_from_cloudflare {
header_up Lb-Hash {remote_host}:{remote_port}
lb_policy ip_hash
handle * {
respond 404
handle_errors {
@errors {
expression {http.error.status_code} == '502'
rewrite @errors /{http.error.status_code}.html
file_server {
root /var/www
#dev only : to work on laptop localhost
#tls internal
# Custom domains
(custom_domains) {
import log /var/log/caddy/custom_{args.0}_req.log
route {
import badbots_filter
# render a special page when on root so the user can see if
# its custom domain is correctly setted up
header / {
X-Cache-Debug "custom.cname_ok"
Server ""
file_server / {
root /var/www/lemlist_cname_ok
# pass all requests "track open/click" to track
@track {
path_regexp ^/api/(t/c|track/open|reply)/
header @track {
X-Cache-Debug "custom.track"
Server ""
reverse_proxy @track {
to localhost:42160
# pass all requests "images + pages" to images
@images {
path /*
header @images {
X-Cache-Debug "custom.images"
Server ""
reverse_proxy @images {
to localhost:42140
handle * {
respond 404
# WARNING : DO NOT add any other site address than :443 here
:443
import custom_domains on_demand
on_demand
issuer acme {
dir https://acme.zerossl.com/v2/DV90
eab ...
issuer acme {
dir https://acme-v02.api.letsencrypt.org/directory
pages.lemlist.com
import custom_domains predefined
# WARNING : DO NOT add any other site address than :80 here
:80
import custom_domains port80
# public direct access to service
(public_passthrough) {
{args.0}
import log /var/log/caddy/public_passthrough_{args.0}_req.log
route {
request_body {
max_size 20MB
header * {
X-Cache-Debug "{args.0}.main"
Server ""
reverse_proxy * {
to localhost:{args.1}
import public_passthrough api.lemlist.com 42100
import public_passthrough img.lemlist.com 42150
# https://front.lempire.co -> admin
import public_passthrough front.lem.ovh 8000
# private direct access to services
(private_passthrough) {
front.lem.ovh:{args.0}
import log /var/log/caddy/private_passthrough_{args.0}_req.log
route {
@cache_version {
# 1d expiration
X-Cache-Debug "direct.cache_version"
Server ""
header * {
X-Cache-Debug "direct.main"
Server ""
reverse_proxy * {
basicauth * {
zzz ....
# Fronts
import private_passthrough 43001 42001
import private_passthrough 43002 42002
import private_passthrough 43003 42003
import private_passthrough 43004 42004
import private_passthrough 43005 42005
import private_passthrough 43006 42006
import private_passthrough 43007 42007
import private_passthrough 43008 42008
# API
import private_passthrough 43100 42100
# Cron
import private_passthrough 43130 42130
# Images Front
import private_passthrough 43150 42150
# Track
import private_passthrough 43160 42160
# Images
import private_passthrough 43140 42140
About once per month, after days running fine, site in unreachable:
curl -k -vvv https://img.lemlist.com
* Trying 147.135.229.201...
* TCP_NODELAY set
* Connected to img.lemlist.com (147.135.229.201) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/cert.pem
CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS alert, internal error (592):
* error:14004438:SSL routines:CONNECT_CR_SRVR_HELLO:tlsv1 alert internal error
* Closing connection 0
curl: (35) error:14004438:SSL routines:CONNECT_CR_SRVR_HELLO:tlsv1 alert internal error
Even if certificate is valid, and less than 2 months old.
When it happens, got tons of :
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.2718267,"logger":"http.stdlib","msg":"http: TLS handshake error from 54.36.63.50:60384: no certificate available for 'img.lemlist.com'"}
2021-08-05 07:54:12
{"level":"debug","ts":1628142852.7338707,"logger":"http.stdlib","msg":"http: TLS handshake error from 54.36.63.50:47688: no certificate available for 'img.lemlist.com'"}
2021-08-05 07:54:11
{"level":"debug","ts":1628142851.146231,"logger":"http.stdlib","msg":"http: TLS handshake error from 54.36.63.50:45850: no certificate available for 'img.lemlist.com'"}
After restart caddy:
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0244107,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0244377,"logger":"http","msg":"starting server loop","address":"[::]:43003","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0244606,"logger":"http","msg":"starting server loop","address":"[::]:43140","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0244842,"logger":"http","msg":"starting server loop","address":"[::]:43100","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0245056,"logger":"http","msg":"starting server loop","address":"[::]:43002","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0245278,"logger":"http","msg":"starting server loop","address":"[::]:43005","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0245743,"logger":"http","msg":"starting server loop","address":"[::]:43006","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0246098,"logger":"http","msg":"starting server loop","address":"[::]:43007","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0246308,"logger":"http","msg":"starting server loop","address":"[::]:43008","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0246575,"logger":"http","msg":"starting server loop","address":"[::]:43001","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0247173,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0247524,"logger":"http","msg":"starting server loop","address":"[::]:43004","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0247736,"logger":"http","msg":"starting server loop","address":"[::]:43130","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0248327,"logger":"http","msg":"starting server loop","address":"[::]:43160","http3":false,"tls":true}
2021-08-05 07:54:30
{"level":"info","ts":1628142870.024842,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["app.lemlist.com","front.lem.ovh","app2.lemlist.com","api.lemlist.com","img.lemlist.com","pages.lemlist.com"]}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.0256736,"logger":"tls","msg":"loading managed certificate","domain":"app.lemlist.com","expiration":1631525890,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.1930182,"logger":"tls","msg":"loading managed certificate","domain":"front.lem.ovh","expiration":1633242076,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
2021-08-05 07:54:30
{"level":"debug","ts":1628142870.4712768,"logger":"tls","msg":"loading managed certificate","domain":"img.lemlist.com","expiration":1634652604,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
I enabled debug logging as suggested in a previosu thread:
