vedam
(Achim Vedam)
June 23, 2016, 2:40pm
1
Trying to setup my simple site
caddyfile:
vedam.me {
ext .html .md
templates
gzip
cors
tls my-adress@used-for-certs.demo # automatic tls, create or renew certs
root /var/www # static files
ports are open ufw status:
80/tcp ALLOW IN Anywhere
443/tcp ALLOW IN Anywhere
80/tcp (v6) ALLOW IN Anywhere (v6)
443/tcp (v6) ALLOW IN Anywhere (v6)
page loads, seems working (browsing with safari, chrome or firefox ) but
log shows error-message:
Jun 23 10:10:11 vedam.me caddy[5668]: 2016/06/23 10:10:11 http2: server: error reading preface from client [2003:c3:abc6:700:57a:e7c8:13f0:3f6b]:55993: timeout waiting for client preface
I’m not able to figure out, what I’m doing wrong
thx in advance
achim
jacob
(Jacob Hands)
June 23, 2016, 3:00pm
2
Hello Achim, welcome to the Caddy forum!
I searched around for this error, and found the relevant error in the http2 package:
} else if !bytes.Equal(buf, clientPreface) {
errc <- fmt.Errorf("bogus greeting %q", buf)
} else {
errc <- nil
timer := time.NewTimer(prefaceTimeout) // TODO: configurable on *Server?
defer timer.Stop()
select {
case <-timer.C:
return errors.New("timeout waiting for client preface")
case err := <-errc:
if err == nil {
sc.vlogf("client %v said hello", sc.conn.RemoteAddr())
return err
// writeDataFromHandler writes the data described in req to stream.id.
It looks like the client might not be sending a proper request. But I’m not really sure exactly.
@matt what do you think?
vedam
(Achim Vedam)
June 23, 2016, 3:05pm
3
@jacob yeah, thx. I also tried to google first and found these. But I don’t know what it should tell me and where to start with.
jacob
(Jacob Hands)
June 23, 2016, 3:06pm
4
Well since it’s an issue in the http2 package this may be a better issue to raise with them.
matt
(Matt Holt)
June 23, 2016, 4:13pm
5
Yeah I see these too sometimes but with no known ill effects. It could be a bug in the http2 implementation or it is probably something wacky that browsers are doing. They do strange things with connections; debugging server-side with browsers is generally a bad idea because of their complexity. Instead, try a simpler HTTP client like curl.
