TLS: error reading preface from client
Hi Matt et al,
In reference to an older issue, Error reading preface from client - #2 by jacob
Hi, I’m a maintainer of https://github.com/swarmstack/swarmstack, which uses Caddy. At the time of the above issue, it was mentioned that there were no known ill side-effects. I’m facing an issue with the reauth module, and wondering if this might be the culprit. When adding the “failure” line below, HTTPS connections to the Caddy port/path log the output (bottom), and immediately the redirect occurs (successfully). No authentication dialog is presented first. If I remove the failure line, authentication occurs normally. However, if the authentication fails (user mistypes credentials) then a Caddy server error is encountered. I’d like to instead redirect them to the page to attempt the authentication again (or if unsupported behavior then just redirect the user to a static page).
:9090 {
tls self_signed
errors stderr
reauth {
path /
ldap url=ldaps://REMOVED(objectClass=user)(uid=%s))"
failure redirect target=https://somehost.example.com/?redir={uri}/,code=303
proxy / prometheus:9090 {
swarmstack_caddy.1.qvk7ufy3y4t5@swarm02.example.com | 2018/10/18 15:46:12 http2: server: error reading preface from client 10.255.0.2:52215: remote error: tls: bad certificate
swarmstack_caddy.1.qvk7ufy3y4t5@swarm02.example.com | 2018/10/18 15:47:32 http2: server: error reading preface from client 10.255.0.2:52234: remote error: tls: bad certificate
Hi @Mike_Holloway,
While someone might be able to help you with this here, your best bet would be to bring this to the author of the reauth plugin.
Thanks Whitestrake, link for search: [ldap] Trying to log in with unknown user yields error 500 · Issue #19 · freman/caddy-reauth · GitHub
