Hello guys, recently I set my domain in the server, originally I was using the IP and everything was working great, now, after set my domain, when I connect my local development environment (a react app) to the server I get the classic CORS error:
Access to XMLHttpRequest at ‘https://api./api/v0/auth/login’ from origin ‘http://localhost:3000’ has been blocked by CORS policy: Response to preflight request doesn’t pass access control check: It does not have HTTP ok status.
checking some post I changed my caddy file to
api.<URL> {
header Access-Control-Allow-Methods "POST,PATCH,PUT,DELETE, GET, OPTIONS"
header Access-Control-Allow-Headers "*"
header Access-Control-Allow-Origin *
header Cache-Control max-age=3600
reverse_proxy localhost:1200
in my understand it must be enough in order to enable CORS, also my webserver has enabled CORS
api.Use(middleware.CORSWithConfig(middleware.CORSConfig{
AllowOrigins: []string{"*"},
AllowMethods: []string{echo.GET, echo.HEAD, echo.PUT, echo.PATCH, echo.POST, echo.DELETE},
these are the caddy logs
root@xxxx-01:~# 2021/03/31 20:02:02.117 ERROR http.log.error dial tcp 127.0.0.1:1200: connect: connection refused {"request": {"remote_addr": "xxx:20259", "proto": "HTTP/2.0", "method": "OPTIONS", "host": "api.<url>", "uri": "/api/v0/auth/register", "headers": {"Sec-Fetch-Dest": ["empty"], "Access-Control-Request-Headers": ["content-type"], "Origin": ["http://localhost:3000"], "Sec-Fetch-Mode": ["cors"], "Sec-Fetch-Site": ["cross-site"], "Accept-Encoding": ["gzip, deflate, br"], "Accept-Language": ["es-419,es;q=0.9,es-ES;q=0.8,en;q=0.7,en-GB;q=0.6,en-US;q=0.5"], "Accept": ["*/*"], "Access-Control-Request-Method": ["POST"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 11_2_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4437.0 Safari/537.36 Edg/91.0.831.1"], "Referer": ["http://localhost:3000/"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "api.rockets-test.ml"}}, "duration": 0.000448227, "status": 502, "err_id": "set557z0w", "err_trace": "reverseproxy.statusError (reverseproxy.go:817)"}
2021/03/31 20:02:38.409 ERROR http.log.error dial tcp 127.0.0.1:1200: connect: connection refused {"request": {"remote_addr": "186.167.250.106:36246", "proto": "HTTP/2.0", "method": "OPTIONS", "host": "api.rockets-test.ml", "uri": "/api/v0/auth/login", "headers": {"Access-Control-Request-Method": ["POST"], "Access-Control-Request-Headers": ["content-type"], "Origin": ["http://localhost:3000"], "Sec-Fetch-Dest": ["empty"], "Referer": ["http://localhost:3000/"], "Accept-Encoding": ["gzip, deflate, br"], "Accept": ["*/*"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 11_2_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.90 Safari/537.36 Edg/89.0.774.63"], "Sec-Fetch-Mode": ["cors"], "Sec-Fetch-Site": ["cross-site"], "Accept-Language": ["es-419,es;q=0.9,es-ES;q=0.8,en;q=0.7,en-GB;q=0.6,en-US;q=0.5"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "api.rockets-test.ml"}}, "duration": 0.000473975, "status": 502, "err_id": "qypyxxcre", "err_trace": "reverseproxy.statusError (reverseproxy.go:817)"}
I’m curious about that reverseproxy.statusError (reverseproxy.go:817)
do you know which could be the issue here? any help will be appreciated…
thank you so much guys, have a great day…
v2.4.0-beta.1 h1:Ed/tIaN3p6z8M3pEiXWJL/T8JmCqV62FrSJCHKquW/I=
ubuntu
paste command here
paste full file contents here
api. {
header Access-Control-Allow-Methods “POST,PATCH,PUT,DELETE, GET, OPTIONS”
header Access-Control-Allow-Headers “*”
use `caddy fmt` to make it readable
or helpers will be sad
