Error enabling CORS (from https to http)
Hello everyone, I am trying to connect my local development environment (a react app) to the server I get the classic CORS error:
Access to XMLHttpRequest at 'http://localhost:8000/my_url' from origin 'https://localhost' has been blocked by CORS policy: Request header field authorization is not allowed by Access-Control-Allow-Headers in preflight response.
I know this question is similar to this topic however in my case my backend is actually receiving my requests.
macOS Monterey
(cors) {
  @origin{args.0} header Origin {args.0}
  header @origin{args.0} Access-Control-Allow-Origin "{args.0}"
localhost {
	header Access-Control-Allow-Methods "POST,PATCH,PUT,DELETE, GET, OPTIONS"
	header Access-Control-Allow-Headers "*"
    header Access-Control-Allow-Origin *
	reverse_proxy http://localhost:4000
	reverse_proxy /candidates/* http://localhost:3000
	reverse_proxy /app/enterprise/* http://localhost:3001
	reverse_proxy proxy.localhost/*
I have multiple react projects that have multiple network requests coded. I use caddy to redirect the urls from the petitions to my local running environment. Everything was working fine until some CORS restrictions were added to the code. It seems the specific problem is that my localhost is using http instead of the expected https requests by caddy.
I have modified my caddyfile multiple times in an effort for it to allow CORS.
I also installed Moesif CORS chrome extension but no luck.
Lastly I tried disabling https requests adding auto_https off in my caddyfile
Please upgrade to v2.4.6!
Doesn’t seem like you’re using this snippet :thinking:
This doesn’t make sense. What are you trying to do here? It neither has a matcher (i.e. something starting with @ or /) nor is a valid upstream address (you can’t have a path in an upstream address).
If that’s the case, then you should make sure your app is properly configured to use the same scheme as the page it’s on. But also, it looks like it’s making a request to port 8000, which isn’t one Caddy is listening on.
Either way, CORS isn’t really a Caddy issue, it’s browser/client issue.
