Dockerised Caddy V2 + Nextcloud-FPM to create an unsecured Nextcloud instance
2.1.1
Docker on Ubuntu Desktop 18.4.04
sudo docker-compose up -d
version: '2'
  nextcloud:
  db:
  caddy_data:
  db:
    image: mariadb
    command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW
    restart: always
      - db:/var/lib/mysql
      - MYSQL_ROOT_PASSWORD=ABC
      - MYSQL_PASSWORD=123
      - MYSQL_DATABASE=nextcloud
      - MYSQL_USER=nextcloud
  app:
    image: nextcloud:fpm
    links:
      - db
      - nextcloud:/var/www/html
    restart: always
  web:
    image: caddy
    links:
      - app
      - caddy_data:/data   # Is this mandatory?
    volumes_from:
      - app
    restart: always
        root    * /usr/local/www/nextcloud
                output file     /var/log/mydomain.com.log
        php_fastcgi 127.0.0.1:9000
                # enable HSTS
                # Strict-Transport-Security max-age=31536000;
        @forbidden {
                path    /.htaccess
                path    /data/*
                path    /config/*
                path    /db_structure
                path    /.xml
                path    /README
                path    /3rdparty/*
                path    /lib/*
                path    /templates/*
                path    /occ
                path    /console.php
        respond @forbidden 404
This thread follows on from the thread Dockerised Nextcloud+Apache web server behind a Caddy reverse proxy - #3 by basil. In that thread, I used a Nextcloud Base version - apache image sourced from Docker Hub to build a Nextcloud instance.
The Quick Reference Guide for Nextcloud on Docker Hub also refers to a Nextcloud image Base version - FPM, which requires another container to act as a webserver. The compose file example (reproduced below) used nginx for the webserver.
version: '2'
  nextcloud:
  db:
  db:
    image: mariadb
    restart: always
      - db:/var/lib/mysql
      - MYSQL_PASSWORD=
  app:
    links:
      - db
    restart: always
  web:
    image: nginx
    links:
      - app
      - ./nginx.conf:/etc/nginx/nginx.conf:ro
    volumes_from:
      - app
    restart: always
The example uses a configuration file nginx.conf, which I’ve included a reference to in Section 6: Links to relevant resources. Anyway, I tried the example and managed to get an insecure Nextcloud instance up very quickly.
I then thought to myself that it would a useful exercise to see if I could replace nginx with Caddy as the webserver. This would require updating the web services section of the compose file. This is what led me to the compose file in Section 2c above.
I did search the forum to see if anyone has already gone down this path. I found this thread Caddy + Nextlcoud fpm, both in docker containers. However, that thread seemed to be for a secured Nextcloud instance and used Caddy V1.
I still needed a Caddyfile for the webserver (the equivalent of nginx.conf). I was already aware of this forum thread Help to migrate Caddyfile V1 to V2 for Nextcloud and based the Caddyfile at step 2d above on the solution for that thread.
Trying to access the unsecured Nextcloud instance throws up the error shown below.
Log output from the webserver below.
administrator@ubuntu-test-bhyve:~/ncfpm$ sudo docker logs -f ncfpm_web_1
{"level":"info","ts":1597079779.6737692,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1597079779.6994681,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["127.0.0.1:2019","localhost:2019","[::1]:2019"]}
{"level":"info","ts":1597079779.7013721,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1597079779.7069006,"logger":"tls","msg":"cleaned up storage units"}
{"level":"info","ts":1597079779.707641,"msg":"autosaved config","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1597079779.7077985,"msg":"serving initial configuration"}
2020/08/10 17:16:19 [INFO][cache:0xc00023fd40] Started certificate maintenance routine
I tried with and without the volume - caddy_data:/data # Is this mandatory? in the compose file. It made no difference.
I wasn’t sure whether the address used in the Caddyfile was correct. I tried both :80 and :4444, but neither made any difference.
  1. Dockerised Nextcloud+Apache web server behind a Caddy reverse proxy - #3 by basil
  2. Quick Reference Guide for Nextcloud on Docker Hub
  3. nginx.conf
  4. Caddy + Nextlcoud fpm, both in docker containers
  5. Help to migrate Caddyfile V1 to V2 for Nextcloud
Yes, if you don’t want to lose your certificates and keys for your domains and potentially hit rate limits if the container restarts in a tight loop due to some error.
This assumes php-fpm is running in the same container as Caddy. 127.0.0.1 will only connect to things in the same container. In Docker, typically I name my container that runs php-fpmphp-fpm. So you would use php_fastcgi php-fpm:9000.
In your case, since nextcloud comes with fpm with that image flavor, you should be able to use app:9000 instead? Make sure that Caddy has access to the same /var/www/html volume, because it needs to be aware of which files exist on disk to properly handle the rewrites and fastcgi communication.
Is this still true if the Nextcloud instance is unsecured (noSSL)?
Yes! Yes! Yes! I’ve learnt something new. The working V2 Caddyfile:
        root    * /var/www/html
        php_fastcgi app:9000
                # enable HSTS
        @forbidden {
                path    /.htaccess
                path    /data/*
                path    /config/*
                path    /db_structure
                path    /.xml
                path    /README
                path    /3rdparty/*
                path    /lib/*
                path    /templates/*
                path    /occ
                path    /console.php
There’s no harm in keeping the volume persisted anyways. Caddy may store other things than just TLS information.
