Debugging "aborting with incomplete response"
Docker via slothcroissant/caddy-cloudflaredns
See: Aborting with incomplete response
I’d like to see if there are ways one could debug the error "http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled".
I know it’s not an “issue” per se - however my docker logs are absolutely piled full of this error message and if nothing else, I’d like to figure out what application I’m hosting behind Caddy is causing it so I can dig in further if needed. (Alternatively, a way to silence this log would be nice :slight_smile: ).
I’ve tried some debug log things, but I couldn’t seem to get anything beyond what’s shown below to populate:
{"level":"error","ts":1646670691.8830473,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670692.884886,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670697.0600572,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670731.007158,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670736.8877547,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670738.0831406,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670765.9784184,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670771.9227834,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670773.1522548,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670798.1662176,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670800.997856,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670806.9451797,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670835.9819987,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670842.0014179,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670843.190441,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670870.9814303,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670876.9677038,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670878.1804051,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
{"level":"error","ts":1646670902.0273228,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
My current debug logs ref:
            level DEBUG
            output file /data/logs/caddy.log {
                    roll_size 10MiB
                    roll_keep 10
                    roll_keep_for 336h
            format json {
                    time_format     iso8601
Is this configured in global options, or in each site?
There’s a difference between access logs and Caddy’s runtime logs. The access logs never emit debug level logs.
You can turn on the debug global option to get more detailed runtime logs.
I do think I have this under each site, so it’s probably just taking site-specific access logs debugs.
Will enable globally and see what I can see. Will let you know - thanks!
