Aborting with incomplete response
2.2.1, custom built with Caddy Docker Proxy and Cloudflare support
OS: Ubuntu 20.04.1 LTS
Docker: 19.03.8
Docker Compose: 1.23.2
docker-compose up -d
version: "3.4"
    build: .
    env_file:
      - .caddy-env
      - /var/www/files:/var/www
      - caddy_data:/data
      - 443:443
    labels:
      caddy_1.email: "i.am@chrisrees.dev"
      caddy_1.admin: "off"
      caddy_2: (cloudflare-tls)
      caddy_2.tls.dns: "cloudflare {env.CLOUDFLARE_API_KEY}"
      caddy_3: files.chrisrees.dev
      caddy_3.file_server: "browse"
      caddy_3.root: "* /var/www"
      caddy_3.import: "cloudflare-tls"
  codex:
    image: ajslater/codex
    container_name: codex
      - PUID=992 # ubooquity
      - PGID=995 # media
      - TZ=America/New_York
      - UMASK_SET=002
      - /data/config/codex:/config
      - /data/media/Comics:/comics
    depends_on:
      - caddy
    labels:
      caddy: codex.chrisrees.dev
      # caddy: comics.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 9810}}"
      caddy.reverse_proxy.flush_interval: -1
      caddy.import: "cloudflare-tls"
  ddclient:
    image: ghcr.io/linuxserver/ddclient
    container_name: ddclient
      - PUID=988 # ddclient
      - PGID=988 # ddclient
      - /data/config/ddclient:/config
  dozzle:
    image: amir20/dozzle
    container_name: dozzle
    depends_on:
      - caddy
    labels:
      caddy: dozzle.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 8080}}"
  grocy:
    image: ghcr.io/linuxserver/grocy
    container_name: grocy
      - PUID=982 # grocy
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/grocy:/config
    depends_on:
      - caddy
    labels:
      caddy: grocy.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 80}}"
  lidarr:
    image: ghcr.io/linuxserver/lidarr
    container_name: lidarr
      - PUID=994 # lidarr
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/lidarr:/config
      - /data:/data
    depends_on:
      - caddy
      - sabnzbd
    labels:
      caddy: lidarr.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 8686}}"
  lychee:
    image: ghcr.io/linuxserver/lychee
    container_name: lychee
    env_file: .lychee-env
      - PUID=981 # lychee
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/lychee:/config
      - /data/media/sync/Serneum/files/Pictures/lychee:/pictures
    depends_on:
      - caddy
      - mariadb
    labels:
      caddy: lychee.chrisrees.dev
  mariadb:
    image: ghcr.io/linuxserver/mariadb
    container_name: mariadb
      - PUID=118 # mysql
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/mariadb:/config
  mylar:
    image: ghcr.io/linuxserver/mylar3:nightly
    container_name: mylar
      - PUID=991 # mylar
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/mylar:/config
      - /data:/data
    depends_on:
      - caddy
      - sabnzbd
    labels:
      caddy: mylar.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 8090}}"
  nextcloud:
    image: ghcr.io/linuxserver/nextcloud
    container_name: nextcloud
      - PUID=989 # nextcloud
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/nextcloud:/config
      - /data/media/sync:/data
    depends_on:
      - caddy
      - mariadb
    labels:
      caddy: nextcloud.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 443}}"
      caddy.reverse_proxy.transport: http
      caddy.reverse_proxy.transport.tls_insecure_skip_verify: "{{\"\"}}"
      caddy.encode: "gzip"
  nzbhydra:
    image: ghcr.io/linuxserver/nzbhydra2
    container_name: nzbhydra
      - PUID=987 # nzbhydra
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/nzbhydra:/config
      - /data:/data
    depends_on:
      - caddy
      - sabnzbd
    labels:
      caddy: hydra.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 5076}}"
  organizr:
    image: organizr/organizr
    container_name: organizr
      - PUID=985 # organizr
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/organizr:/config
      - /data:/data
    depends_on:
      - caddy
    labels:
      caddy: organizr.chrisrees.dev
  plex:
    image: ghcr.io/linuxserver/plex
    container_name: plex
      - PUID=117 # plex
      - PGID=995 # media
      - VERSION=docker
      - UMASK_SET=002
      - /data/config/plex:/config
      - /data/media:/data
    depends_on:
      - caddy
    labels:
      caddy: plex.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 32400}}"
    devices:
      - /dev/dri:/dev/dri
  radarr:
    image: ghcr.io/linuxserver/radarr
    container_name: radarr
      - PUID=995 # radarr
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/radarr:/config
      - /data:/data
    depends_on:
      - caddy
      - sabnzbd
    labels:
      caddy: radarr.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 7878}}"
  sabnzbd:
    image: ghcr.io/linuxserver/sabnzbd
    container_name: sabnzbd
      - PUID=993 # sabnzbd
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/sabnzbd:/config
      - /data/usenet:/data/usenet
    depends_on:
      - caddy
    labels:
      caddy: sabnzbd.chrisrees.dev
  signald:
    image: finn/signald
    container_name: signald
      - /data/config/signald/run:/signald
  sonarr:
    image: ghcr.io/linuxserver/sonarr:preview
    container_name: sonarr
      - PUID=997 # sonarr
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/sonarr:/config
      - /data:/data
    depends_on:
      - caddy
      - sabnzbd
    labels:
      caddy: sonarr.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 8989}}"
  speedtest:
    image: henrywhitaker3/speedtest-tracker
    container_name: speedtest
      - PUID=984 # speedtest
      - PGID=995 # media
      - UMASK=002
      - OOKLA_EULA_GDPR=true
      - AUTH=true
      - /data/config/speedtest:/config
    depends_on:
      - caddy
    logging:
      driver: "json-file"
      options:
        max-file: "10"
        max-size: "200k"
    labels:
      caddy: speedtest.chrisrees.dev
  syncthing:
    image: ghcr.io/linuxserver/syncthing
    container_name: syncthing
      - PUID=990 # syncthing
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/syncthing:/config
      - 22000:22000
      - 21027:21027/udp
    depends_on:
      - caddy
    labels:
      caddy: sync.chrisrees.dev
      caddy.reverse_proxy: "/* {{upstreams 8384}}"
  thelounge:
    image: ghcr.io/linuxserver/thelounge
    container_name: thelounge
      - PUID=983 # thelounge
      - PGID=995 # media
      - UMASK_SET=002
      - /data/config/thelounge:/config
    depends_on:
      - caddy
    labels:
      caddy: lounge.chrisrees.dev
      caddy.reverse_proxy: "{{upstreams 9000}}"
  caddy_data: {}
See comment to avoid hitting the character limit
I’ve noticed these logs popping up periodically and am unsure of what they really mean or what I can do to solve them
yesterday at 3:35 AM  {"level":"error","ts":1609403700.296945,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:36 AM  {"level":"error","ts":1609403803.4472125,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:38 AM  {"level":"error","ts":1609403906.8651874,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:40 AM  {"level":"error","ts":1609404010.735137,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:41 AM  {"level":"error","ts":1609404114.2361896,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:43 AM  {"level":"error","ts":1609404217.694259,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:45 AM  {"level":"error","ts":1609404321.673235,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:47 AM  {"level":"error","ts":1609404425.078202,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:48 AM  {"level":"error","ts":1609404528.734216,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:50 AM  {"level":"error","ts":1609404631.861046,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:51 AM  {"level":"error","ts":1609404680.384811,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:52 AM  {"level":"error","ts":1609404779.6926677,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:29 AM  {"level":"error","ts":1609428542.659997,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:30 AM  {"level":"error","ts":1609428645.9888477,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:32 AM  {"level":"error","ts":1609428749.9139576,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:34 AM  {"level":"error","ts":1609428853.09779,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:35 AM  {"level":"error","ts":1609428957.150645,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:37 AM  {"level":"error","ts":1609429061.150932,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:39 AM  {"level":"error","ts":1609429165.253752,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:41 AM  {"level":"error","ts":1609429269.079028,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:42 AM  {"level":"error","ts":1609429373.098621,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:44 AM  {"level":"error","ts":1609429476.6597562,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:46 AM  {"level":"error","ts":1609429580.5916452,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:48 AM  {"level":"error","ts":1609429684.6039712,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:49 AM  {"level":"error","ts":1609429788.7203343,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:51 AM  {"level":"error","ts":1609429892.6537583,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:54 AM  {"level":"error","ts":1609430079.6389182,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:54 AM  {"level":"error","ts":1609430079.702885,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:56 AM  {"level":"error","ts":1609430183.7740085,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:58 AM  {"level":"error","ts":1609430287.581291,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 10:59 AM  {"level":"error","ts":1609430391.5822973,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:01 AM  {"level":"error","ts":1609430506.16556,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:01 AM  {"level":"error","ts":1609430507.711836,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:01 AM  {"level":"error","ts":1609430507.7928784,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:03 AM  {"level":"error","ts":1609430610.9539316,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:05 AM  {"level":"error","ts":1609430715.0620363,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:06 AM  {"level":"error","ts":1609430819.0674253,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:08 AM  {"level":"error","ts":1609430922.9815245,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:10 AM  {"level":"error","ts":1609431026.9876127,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:12 AM  {"level":"error","ts":1609431130.1523705,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:16 AM  {"level":"error","ts":1609431397.6590524,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:18 AM  {"level":"error","ts":1609431500.9538388,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:20 AM  {"level":"error","ts":1609431604.951055,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:21 AM  {"level":"error","ts":1609431680.641389,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:22 AM  {"level":"error","ts":1609431779.6955495,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:57 AM  {"level":"error","ts":1609433852.3242965,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 11:59 AM  {"level":"error","ts":1609433969.3511887,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:02 PM  {"level":"error","ts":1609434157.6142793,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:05 PM  {"level":"error","ts":1609434335.946595,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:10 PM  {"level":"error","ts":1609434649.8175187,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:12 PM  {"level":"error","ts":1609434753.3045049,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:14 PM  {"level":"error","ts":1609434857.236571,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:17 PM  {"level":"error","ts":1609435045.7093198,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:19 PM  {"level":"error","ts":1609435149.3935227,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:20 PM  {"level":"error","ts":1609435253.3971536,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:22 PM  {"level":"error","ts":1609435357.382438,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:24 PM  {"level":"error","ts":1609435461.240424,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:26 PM  {"level":"error","ts":1609435564.5079806,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:27 PM  {"level":"error","ts":1609435667.8858945,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:29 PM  {"level":"error","ts":1609435771.3121865,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:31 PM  {"level":"error","ts":1609435874.5859241,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:32 PM  {"level":"error","ts":1609435977.8619628,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:34 PM  {"level":"error","ts":1609436081.768129,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:37 PM  {"level":"error","ts":1609436243.1578662,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:38 PM  {"level":"error","ts":1609436339.6970673,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 12:40 PM  {"level":"error","ts":1609436439.4951704,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:17 PM  {"level":"error","ts":1609438637.6115441,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:19 PM  {"level":"error","ts":1609438741.1774645,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:21 PM  {"level":"error","ts":1609438870.6455677,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:22 PM  {"level":"error","ts":1609438974.5989978,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:24 PM  {"level":"error","ts":1609439078.3464766,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:26 PM  {"level":"error","ts":1609439182.3655074,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:28 PM  {"level":"error","ts":1609439286.362469,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:30 PM  {"level":"error","ts":1609439438.0095048,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 1:32 PM  {"level":"error","ts":1609439537.6401463,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
yesterday at 3:32 PM  {"level":"info","ts":1609446720.6991441,"logger":"tls","msg":"cleaned up storage units"}
yesterday at 6:40 PM  {"level":"error","ts":1609458049.7018754,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.128.4:443->108.162.216.226:57308: write: connection reset by peer"}
yesterday at 6:41 PM  {"level":"error","ts":1609458064.1281474,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 192.168.128.4:443->108.162.216.226:57314: write: broken pipe"}
today at 1:51 AM  {"level":"error","ts":1609483885.5967984,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 1:53 AM  {"level":"error","ts":1609483988.8919003,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 1:54 AM  {"level":"error","ts":1609484092.8145595,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 1:56 AM  {"level":"error","ts":1609484206.8441145,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 1:58 AM  {"level":"error","ts":1609484310.148266,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:00 AM  {"level":"error","ts":1609484414.1352534,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:02 AM  {"level":"error","ts":1609484545.0905962,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:04 AM  {"level":"error","ts":1609484649.145482,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:05 AM  {"level":"error","ts":1609484752.5161886,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:08 AM  {"level":"error","ts":1609484896.6852808,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:10 AM  {"level":"error","ts":1609485000.1186495,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:13 AM  {"level":"error","ts":1609485207.4215553,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:14 AM  {"level":"error","ts":1609485264.989103,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 2:16 AM  {"level":"error","ts":1609485364.350466,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 8:51 AM  {"level":"error","ts":1609509081.5631945,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
today at 8:53 AM  {"level":"error","ts":1609509185.535363,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
I tried implementing the flush_interval -1 from Context cancelled when Webpack HMR sends updates on all of my services with no luck
Config JSON
  "admin": {
    "disabled": true
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [
            ":443"
          "routes": [
              "match": [
                  "host": [
                    "nextcloud.chrisrees.dev"
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "encodings": {
                            "gzip": {}
                          "handler": "encode"
                          "flush_interval": -1,
                          "handler": "reverse_proxy",
                          "transport": {
                            "protocol": "http",
                            "tls": {
                              "insecure_skip_verify": true
                          "upstreams": [
                              "dial": "192.168.128.6:443"
              "terminal": true
              "match": [
                  "host": [
                    "speedtest.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.12:80"
              "terminal": true
              "match": [
                  "host": [
                    "organizr.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.15:80"
              "terminal": true
              "match": [
                  "host": [
                    "sabnzbd.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.9:8080"
              "terminal": true
              "match": [
                  "host": [
                    "dozzle.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.8:8080"
              "terminal": true
              "match": [
                  "host": [
                    "lidarr.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.18:8686"
              "terminal": true
              "match": [
                  "host": [
                    "lounge.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.14:9000"
              "terminal": true
              "match": [
                  "host": [
                    "lychee.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.13:80"
              "terminal": true
              "match": [
                  "host": [
                    "radarr.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.20:7878"
              "terminal": true
              "match": [
                  "host": [
                    "sonarr.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.21:8989"
              "terminal": true
              "match": [
                  "host": [
                    "codex.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.16:9810"
              "terminal": true
              "match": [
                  "host": [
                    "files.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "handler": "vars",
                          "root": "/var/www"
                          "browse": {},
                          "handler": "file_server",
                          "hide": [
                            "Caddyfile"
              "terminal": true
              "match": [
                  "host": [
                    "grocy.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.7:80"
              "terminal": true
              "match": [
                  "host": [
                    "hydra.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.17:5076"
              "terminal": true
              "match": [
                  "host": [
                    "mylar.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.19:8090"
              "terminal": true
              "match": [
                  "host": [
                    "plex.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.10:32400"
              "terminal": true
              "match": [
                  "host": [
                    "sync.chrisrees.dev"
              "handle": [
                  "routes": [
                      "handle": [
                          "upstreams": [
                              "dial": "192.168.128.11:8384"
                      "match": [
                          "path": [
              "terminal": true
    "tls": {
      "automation": {
        "policies": [
            "subjects": [
              "nextcloud.chrisrees.dev",
              "speedtest.chrisrees.dev",
              "organizr.chrisrees.dev",
              "sabnzbd.chrisrees.dev",
              "dozzle.chrisrees.dev",
              "lidarr.chrisrees.dev",
              "lounge.chrisrees.dev",
              "lychee.chrisrees.dev",
              "radarr.chrisrees.dev",
              "sonarr.chrisrees.dev",
              "codex.chrisrees.dev",
              "files.chrisrees.dev",
              "grocy.chrisrees.dev",
              "hydra.chrisrees.dev",
              "mylar.chrisrees.dev",
              "plex.chrisrees.dev",
            "issuer": {
              "challenges": {
                "dns": {
                  "provider": {
                    "api_token": "<TOKEN>",
                    "name": "cloudflare"
              "email": "i.am@chrisrees.dev",
              "module": "acme"
            "issuer": {
              "module": "acme"
“context canceled” on a request usually means the client closed the connection early; in this case, the proxy started writing the response but couldn’t finish because the client cancelled it. The Go standard library panics here (or at least it used to) but we simply emit a log instead.
I guess we could use more discretion with the log leveling… emit a debug-level log if the error is context.Canceled, otherwise let it stay an error level. It’d be less noisy.
So it sounds like it’s a non-issue just noisy if I’m understanding correctly. If that’s the case, I can live with it but changing the logging level would be nice for the future. I was seeing it somewhat sporadically so I thought it might be a config issue on my side. Thanks!
