I’m trying to use the linux tool curl to access the site hosted by Caddy using LetsEncrypt certificates. The site works in a browser but not via curl.
% curl -v https://app.sportch.localhost
* Trying 127.0.0.1:443...
* Connected to app.sportch.localhost (127.0.0.1) port 443 (#0)
* ALPN: offers h2,http/1.1
* CAfile: /etc/ssl/cert.pem
* CApath: none
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection 0
curl: (60) SSL certificate problem: unable to get local issuer certificate
how to fix it, please visit the web page mentioned above.
latest
docker-composer up
Docker
docker-compose up
version: "0.0.2"
web-network:
image: caddy:latest
restart: always
- ./caddy/data:/data
- ./caddy/config:/config
- ./caddy/logs:/logs
- ./app:/var/www/html
- web-network
# this bit allows caddy on docker to see the listener on the external (to docker) port 8080 (which listens locally on my laptop)
extra_hosts:
host.docker.internal: host-gateway
php:
build: ./php
tty: true
restart: always
- web-network
extra_hosts:
mysql:
image: mysql/mysql-server:latest-aarch64
- "23306:3306"
MYSQL_ROOT_HOST: "%"
MYSQL_ROOT_USER: root
MYSQL_ROOT_PASSWORD: root
MYSQL_DATABASE: aasportch10700
MYSQL_USER: my_user
MYSQL_PASSWORD: my_password
command: mysqld --sql_mode="NO_ENGINE_SUBSTITUTION"
- $PWD/db/data:/var/lib/mysql
- $PWD/db/config:/etc/mysql/conf.d
- web-network
extra_hosts:
phpmyadmin:
image: phpmyadmin
tty: true
working_dir: $PWD/phpmyadmin
- "8888:80"
- web-network
PMA_HOST: "mysql"
PMA_PORT: "3306"
PMA_USER: "root"
PMA_PASSWORD: "root"
app.sportch.localhost {
root * /var/www/html/SportchLegacyApp
php_fastcgi php:9000
header / {
Content-Type text/html
