I’m using caddy for HTTPS requests from client VM to server VM
Caddy was setup on server VM using Docker
after that I copied root.crt file from /data/caddy/pki/authorities/local in the container on server VM and installed it on client VM (by putting it to the /usr/local/share/ca-certificates/mydomain and running sudo update-ca-certificates)
also on client VM I added <IP> mydomain.localhost to /etc/hosts
after that i tried curl to request server VM, and secure connection failed, despite I installed the certificate
# Both command executed on client VM
curl https://mydomain.localhost # FAILS with SSL certificate problem: authority and subject key identifier mismatch
curl -k https://mydomain.localhost # OK
Simple request (without --cacert option)
curl -v https://mydomain.localhost
* Trying <IP>:443...
* Connected to mydomain.localhost (<IP>) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CApath: /usr/lib/ssl/certs
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Unknown (21):
* TLSv1.3 (OUT), TLS alert, certificate unknown (558):
* SSL certificate problem: authority and subject key identifier mismatch
* Closing connection 0
curl: (60) SSL certificate problem: authority and subject key identifier mismatch
how to fix it, please visit the web page mentioned above.
I also tried providing root.crt file to the instruction manually
curl --cacert /root/root.crt -v https://mydomain.localhost
* ALPN, offering h2
* CAfile: /root/root.crt
* CApath: /etc/ssl/certs
Ubuntu
docker-compose up -d
Contents of docker-compose.yaml
version: '3'
image: caddy:latest
- /root/Caddyfile:/etc/caddy/Caddyfile
- /root/caddy.log:/var/log/caddy.log
- /root/caddy_certificates:/data/caddy/certificates/local/mydomain.localhost
- /root/caddy_certificates_pki:/data/caddy/pki/authorities/local
restart: always
network_mode: host
nginx:
image: nginx:stable-alpine3.17
restart: always
- /root/nginx.conf:/etc/nginx/nginx.conf:ro
network_mode: host
mydomain.localhost {
output file /var/log/caddy.log
reverse_proxy localhost:8080
Used that topic to find out about root.crt
