2.2.1
Systemd, with “/path/to/caddy run /path/to/Caddyfile”
Centos 8, with SELinux disabled (running in a Hyper-V 2019 VM). All current updates installed. Using systemd.
as above
# caddy.service
# for your installation.
#User=root
#Group=root
#PrivateTmp=true
#ProtectSystem=full
# Test Caddyfile
email pwh@cassland.org
# Sites
pen2.cassland.org {
root * /var/www/html/cassland_org
basicauth /Nic/* { # directory is browsed
NBH JDJhJDE0JHo5WGN5eGZ6SkNiRlEwYmtaZjlMMWVMeE1rVWIwZjNCNGhDdXJvRGRjVWRxQ1I5V3ozcWpH # something
@browsedirs {
path /Nic
path /Nic/* #basicauth required
file_server @browsedirs browse
handle_errors {
@404 {
expression {http.error.status_code} == "404"
rewrite @404 /404.html # /404.html or /New404.html
output file /var/log/caddy/CLaccess.log
I have a directory, which is browsed, and which is protected by basicauth. If I add a handle_errors directive, the basicauth fails to send the correct status back to the client, which therefore does not proceed to ask for credentials - in the error case, instead of the expected 401 the status returned is logged as 0 but shown by curl as 200.
Without handle_errors:
Log:
192.168.1.74 - - [18/Nov/2020:12:12:37 +0000] "GET /Nic/ HTTP/1.1" 401 0
Curl:
C:\Users\paul.CASS>curl -v https://pen2.cassland.org/Nic/
* Trying 192.168.1.86...
* TCP_NODELAY set
* Connected to pen2.cassland.org (192.168.1.86) port 443 (#0)
* schannel: SSL/TLS connection with pen2.cassland.org port 443 (step 1/3)
* schannel: checking server certificate revocation
* schannel: sending initial handshake data: sending 188 bytes...
* schannel: sent initial handshake data: sent 188 bytes
* schannel: SSL/TLS connection with pen2.cassland.org port 443 (step 2/3)
* schannel: encrypted data got 3100
* schannel: encrypted data buffer: offset 3100 length 4096
* schannel: sending next handshake data: sending 93 bytes...
* schannel: encrypted data got 186
* schannel: encrypted data buffer: offset 186 length 4096
* schannel: SSL/TLS handshake complete
* schannel: SSL/TLS connection with pen2.cassland.org port 443 (step 3/3)
* schannel: stored credential handle in session cache
> GET /Nic/ HTTP/1.1
> Host: pen2.cassland.org
> User-Agent: curl/7.55.1
* schannel: client wants to read 102400 bytes
* schannel: encdata_buffer resized 103424
* schannel: encrypted data buffer: offset 0 length 103424
* schannel: encrypted data got 173
* schannel: encrypted data buffer: offset 173 length 103424
* schannel: decrypted data length: 144
* schannel: decrypted data added: 144
* schannel: decrypted data cached: offset 144 length 102400
* schannel: decrypted data buffer: offset 144 length 102400
* schannel: schannel_recv cleanup
* schannel: decrypted data returned 144
* schannel: decrypted data buffer: offset 0 length 102400
< HTTP/1.1 401 Unauthorized
< Server: Caddy
< Www-Authenticate: Basic realm="restricted"
< Date: Wed, 18 Nov 2020 12:12:37 GMT
< Content-Length: 0
* Connection #0 to host pen2.cassland.org left intact
But when handle_errors is added to the Caddyfile I get the following:
Log:
192.168.1.74 - - [18/Nov/2020:12:13:31 +0000] "GET /Nic/ HTTP/1.1" 0 0
Curl:
* TCP_NODELAY set
* schannel: encrypted data got 3101
* schannel: encrypted data buffer: offset 3101 length 4096
> GET /Nic/ HTTP/1.1
* schannel: encrypted data got 163
* schannel: encrypted data buffer: offset 163 length 103424
* schannel: decrypted data length: 134
* schannel: decrypted data added: 134
* schannel: decrypted data cached: offset 134 length 102400
* schannel: decrypted data buffer: offset 134 length 102400
* schannel: decrypted data returned 134
< HTTP/1.1 200 OK
< Server: Caddy
< Date: Wed, 18 Nov 2020 12:13:31 GMT
< Content-Length: 0
Debug log:
{"level":"error","ts":1605703916.8081162,"logger":"http.log.error.log0","msg":"error handling handler error","request":{"remote_addr":"192.168.1.74:1281","proto":"HTTP/1.1","method":"GET","host":"pen2.cassland.org","uri":"/Nic/","headers":{"User-Agent":["curl/7.55.1"],"Accept":["*/*"]},"tls":{"resumed":false,"version":771,"cipher_suite":49196,"proto":"","proto_mutual":true,"server_name":"pen2.cassland.org"}},"duration":0.0001428,"error":"{id=pcd6e6rcx} fileserver.(*FileServer).notFound (staticfiles.go:386): HTTP 404","first_error":{"msg":"not authenticated","status":401,"err_id":"bsz4y89g5","err_trace":"caddyauth.Authentication.ServeHTTP (caddyauth.go:78)"}}
{"level":"info","ts":1605703916.8096578,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"192.168.1.74:1281","proto":"HTTP/1.1","method":"GET","host":"pen2.cassland.org","uri":"/Nic/","headers":{"User-Agent":["curl/7.55.1"],"Accept":["*/*"]},"tls":{"resumed":false,"version":771,"cipher_suite":49196,"proto":"","proto_mutual":true,"server_name":"pen2.cassland.org"}},"common_log":"192.168.1.74 - - [18/Nov/2020:12:51:56 +0000] \"GET /Nic/ HTTP/1.1\" 0 0","duration":0.0001428,"size":0,"status":0,"resp_headers":{"Server":["Caddy"],"Www-Authenticate":["Basic realm=\"restricted\""]}}
Previously discussed in this thread. The present thread shows the simplest form of the error that I can produce. Not all the problems I discussed before show up in this simple form - in particular, if the protected resource is not browsed and has an index.html file, then in this simple case the problem doesn’t occur.
Paul
But I think that’s a separate issue.
