ctbritt
(Chris Allbritton)
May 18, 2024, 2:54am
1
I have two machines on my local network, a mac running caddy and a pi that i’m trying to reach. The mac is working great. I can ssh in and connect to https node apps. The pi is unreachable via the domain name. ssh will not connect, nor will https. http WILL connect though. Have tried everything. this used to work with an old Pi 4, but when I upgraded to a 5, it went belly up.
When I try to `curl -vL https://pi.azthir-terra.com:50000 , i get the following error:
* Host pi.azthir-terra.com:50000 was resolved.
* IPv6: (none)
* IPv4: 108.51.174.138
* Trying 108.51.174.138:50000...
* Connected to pi.azthir-terra.com (108.51.174.138) port 50000
* CAfile: /etc/ssl/cert.pem
* CApath: none
* LibreSSL/3.3.6: error:1404B42E:SSL routines:ST_CONNECT:tlsv1 alert protocol version
* Closing connection
curl: (35) LibreSSL/3.3.6: error:1404B42E:SSL routines:ST_CONNECT:tlsv1 alert protocol version
When i try to ssh chris@pi.azthir-terra.com -p 1387 i get the following:
ssh: connect to host pi.azthir-terra.com port 1387: Operation timed out
attempting to connect via web browser to either pi.azthir-terra.com:50000 or 108.51.174.138:50000 gives me an error that a secure connection can’t be made.
via homerew. No modifications
MacOS 14.5,
caddy is running as a service. I use the folllowing commands
brew services restart caddy
sudo nano /opt/homebrew/etc/caddyfile
# This replaces the existing content in /etc/caddy/Caddyfile
# Global options block
192.168.5.86 {
# PROXY ALL REQUEST TO PORT 30000
tls internal
reverse_proxy localhost:30000
encode zstd gzip
foundry.azthir-terra.com {
encode zstd gzip
5e.azthir-terra.com {
# PROXY ALL REQUEST TO PORT 5000
root * /Volumes/foundrydisk/5etools-mirror-2.github.io/
file_server browse
encode zstd gzip
pi.azthir-terra.com {
reverse_proxy 192.168.7.121:1387
encode zstd gzip
pi.azthir-terra.com:50000 {
reverse_proxy 192.168.7.121:50000
encode zstd gzip
Any suggestions on what the problem might be would be greatly appreciated
Thanks!
C
ctbritt:
Is that your public IP address? Are you port forwarding port 50000 to your Pi’s LAN IP address in your router?
This doesn’t sound like a problem with Caddy at all, it sounds like a networking issue.
I’m not sure what relevance SSH has here; in case you’re not aware, Caddy is an HTTP server, it can’t proxy SSH traffic. For that, you’d need a TCP proxy like GitHub - mholt/caddy-l4: Layer 4 (TCP/UDP) app for Caddy but keep in mind that SSH does not have the concept of “hostnames” or TLS-SNI, so SSH traffic cannot be routed by domain name.
ctbritt
(Chris Allbritton)
May 18, 2024, 1:36pm
3
Yes, the 108. number is my public address.
The issue is that something — I suspect caddy’s certificates? — is preventing a secure connection to the pi. Like I said, http to the domain works. Https doesn’t. And ssh doesn’t work. And since caddy is providing the cert and handling the reverse proxy, I think there is an issue with the caddy setup. But I can’t seem to suss out what’s blocking it.
Show your Caddy logs. You have the debug global option already which should show it there’s any failed TLS handshakes. But to me it sounds like networking issues.
ctbritt
(Chris Allbritton)
May 18, 2024, 3:47pm
5
how do I show my caddy logs?
Caddy emits its logs to stdout. I don’t use a Mac so I don’t know how that’s set up there.
ctbritt
(Chris Allbritton)
May 18, 2024, 10:39pm
7
i can’t figure out how to access stdout, and logging just locks up caddy. I am giving up.
ctbritt
(Chris Allbritton)
May 18, 2024, 10:40pm
8
this literally used to work perfectly with no issues on my previous Pi. and I diidn’t change anything in my caddy file. So guiess I just won’t access my pi from outside my local network.
Add this to your Caddyfile’s global options block, it should write the logs to a file next to Caddy’s present working directory (I don’t know what that ends up being on Mac, I don’t know how you’re actually running it):
output file caddy.log
ctbritt
(Chris Allbritton)
May 22, 2024, 6:31pm
10
Here’s the log output:
{"level":"warn","ts":1716402647.1361039,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1716402647.137442,"msg":"using provided configuration","config_file":"/opt/homebrew/etc/Caddyfile","config_adapter":""}
{"level":"info","ts":1716402647.1393962,"msg":"redirected default logger","from":"stderr","to":"/caddy.log"}
2024-05-22 14:30:47.141531 -0400 EDT m=+0.034150335 write error: can't open new logfile: open caddy.log: read-only file system
2024-05-22 14:30:47.146531 -0400 EDT m=+0.039149960 write error: can't open new logfile: open caddy.log: read-only file system
2024-05-22 14:30:47.150263 -0400 EDT m=+0.042882293 write error: can't open new logfile: open caddy.log: read-only file system
Error: loading initial config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: provisioning automation policy 1: loading TLS automation management module: position 0: loading module 'internal': provision tls.issuance.internal: loading pki app module: provision pki: provisioning CA 'local': generating root: saving root certificate: mkdir caddy: read-only file system
{"level":"warn","ts":1716402657.257578,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1716402657.2596521,"msg":"using provided configuration","config_file":"/opt/homebrew/etc/Caddyfile","config_adapter":""}
{"level":"info","ts":1716402657.26206,"msg":"redirected default logger","from":"stderr","to":"/caddy.log"}
2024-05-22 14:30:57.264687 -0400 EDT m=+0.084201126 write error: can't open new logfile: open caddy.log: read-only file system
2024-05-22 14:30:57.269022 -0400 EDT m=+0.088536876 write error: can't open new logfile: open caddy.log: read-only file system
2024-05-22 14:30:57.272914 -0400 EDT m=+0.092428709 write error: can't open new logfile: open caddy.log: read-only file system
Try changing the log file path to somewhere else you know is writable. I don’t use a Mac so I don’t know what path is best.
But clearly Caddy’s storage directory is marked as read-only for some reason. That’s a problem with your system setup, you’ll need to figure out a solution for that.
ctbritt
(Chris Allbritton)
May 22, 2024, 7:42pm
12
how do I find out what the storage directory is?
Well it’s meant to be in your $HOME but clearly $HOME isn’t set with the way you’re running Caddy. See Conventions — Caddy Documentation
ctbritt
(Chris Allbritton)
May 22, 2024, 8:10pm
14
ok. how on earth i see what $HOME is for caddy? Like, where is config_file stored?
ctbritt
(Chris Allbritton)
May 22, 2024, 8:28pm
15
Just seeing this over and over in my caddy.log in /opt/homebrew/var/log
{"level":"warn","ts":1716409658.563532,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1716409658.565645,"msg":"using provided configuration","config_file":"/opt/homebrew/etc/Caddyfile","config_adapter":""}
{"level":"info","ts":1716409658.570483,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
{"level":"info","ts":1716409658.570661,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x14000097d00"}
{"level":"info","ts":1716409658.571702,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0x14000097d00"}
That’s a system env var, it’s not something defined in a config file. What is considered “home” depends on how the program is run. I don’t know why it’s not set in your case, I don’t know how Homebrew sets up the program to run etc.
ctbritt
(Chris Allbritton)
May 22, 2024, 8:57pm
17
Ok. Here’s my latest caddy file
192.168.5.86 {
tls internal
encode zstd gzip
encode zstd gzip
file_server browse
encode zstd gzip
192.168.7.121 {
tls internal
reverse_proxy raspberrypi.local
encode zstd gzip
tls internal
reverse_proxy raspberrypi.local:1387
encode zstd gzip
tls internal
reverse_proxy raspberrypi.local:50000
encode zstd gzip
and here’s the message I get when I curl -v https://pi.azthir-terra.com:50000
* IPv6: (none)
* CApath: none
ctbritt
(Chris Allbritton)
May 22, 2024, 8:59pm
18
and here’s the output from curl -v http://pi.azthir-terra.com:50000
* IPv6: (none)
> GET / HTTP/1.1
> Host: pi.azthir-terra.com:50000
> User-Agent: curl/8.6.0
< HTTP/1.1 302 Found
< X-Powered-By: Express
< Location: /join
< Vary: Accept
< Content-Length: 27
< Date: Wed, 22 May 2024 20:58:26 GMT
< Connection: keep-alive
< Keep-Alive: timeout=5
* Connection #0 to host pi.azthir-terra.com left intact
Found. Redirecting to /join%
As you can see, http works. https doesn’t. i’m convinced its a certificate problem somehow. Or I don’t have my caddyfile configured properly.
Mohammed90
(Mohammed Al Sahaf)
May 22, 2024, 9:46pm
19
Homebrew sets the relevant environment variable, i.e. XDG_DATA_HOME, to #{HOMEBREW_PREFIX}/var/lib, per:
`#{HOMEBREW_PREFIX}/var/lib`
instead of the default location found at https://caddyserver.com/docs/conventions#data-directory
EOS
end
service do
run [opt_bin/"caddy", "run", "--config", etc/"Caddyfile"]
keep_alive true
error_log_path var/"log/caddy.log"
environment_variables XDG_DATA_HOME: "#{HOMEBREW_PREFIX}/var/lib"
end
test do
port1 = free_port
port2 = free_port
(testpath/"Caddyfile").write <<~EOS
admin 127.0.0.1:#{port1}
You can check the value of HOMEBREW_PREFIX by running brew config. Once you identify the directory, ensure that directory permissions are correct and allow the user running the service to write. I don’t know which user would that be, but I assume it’s the current user, unless you’re using sudo to run the service. You can ask the Homebrew team that on GitHub to know for sure. Their website doesn’t say anything, and I’m not familiar with their codebase.
Something similar was reported to Homebrew before, but the ever helpful stalebot closed it
opened 09:42AM - 27 Jan 21 UTC
closed 12:18AM - 27 Mar 21 UTC
stale
outdated
# Bug report
**Please note we will close your issue without comment if you de… lete, do not read or do not fill out the issue checklist below and provide ALL the requested information. If you repeatedly fail to use the issue template, we will block you from ever submitting issues to Homebrew again.**
- [x] ran `brew update` and can still reproduce the problem?
- [x] ran `brew doctor`, fixed all issues and can still reproduce the problem?
- [x] ran `brew config` and `brew doctor` and included their output with your issue?
## What you were trying to do (and why)
run caddy server on brew services on osx Big Sur
## What happened (include command output)
<details>
<summary>sudo brew services start caddy</summary>
<pre>
Warning: Taking root:admin ownership of some caddy paths:
/usr/local/Cellar/caddy/2.3.0/bin
/usr/local/Cellar/caddy/2.3.0/bin/caddy
/usr/local/opt/caddy
/usr/local/opt/caddy/bin
/usr/local/var/homebrew/linked/caddy
This will require manual removal of these paths using `sudo rm` on
brew upgrade/reinstall/uninstall.
Warning: caddy must be run as non-root to start at user login!
==> Successfully started `caddy` (label: homebrew.mxcl.caddy)
</pre>
</details>
<details>
<summary>cat /usr/local/var/log/caddy.log</summary>
<pre>
{"level":"warn","ts":1611740307.688664,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1611740307.709192,"msg":"using provided configuration","config_file":"/usr/local/etc/Caddyfile","config_adapter":""}
{"level":"info","ts":1611740307.710888,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1611740307.711073,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003771f0"}
{"level":"info","ts":1611740307.719483,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003771f0"}
run: loading initial config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: provisioning automation policy 0: loading TLS automation management module: position 0: loading module 'internal': provision tls.issuance.internal: loading pki app module: provision pki: provisioning CA 'local': generating root: saving root certificate: mkdir caddy: read-only file system
</pre>
</details>
## What you expected to happen
I expect caddy to start as a service.
## Step-by-step reproduction instructions (by running `brew` commands)
`brew install caddy`
`sudo brew service start caddy`
## Output of `brew config` and `brew doctor` commands
<pre>
toast % brew config
HOMEBREW_VERSION: 2.7.5
ORIGIN: https://github.com/Homebrew/brew
HEAD: bca4804a9e48de5319383d3eddadaa7f054c77da
Last commit: 12 days ago
Core tap ORIGIN: https://github.com/Homebrew/homebrew-core
Core tap HEAD: 2b73acc4463be52b42481656f69f9a89366daee1
Core tap last commit: 83 minutes ago
Core tap branch: master
HOMEBREW_PREFIX: /usr/local
HOMEBREW_CASK_OPTS: []
HOMEBREW_EDITOR: code
HOMEBREW_MAKE_JOBS: 8
HOMEBREW_NO_ANALYTICS: set
Homebrew Ruby: 2.6.3 => /System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/bin/ruby
CPU: octa-core 64-bit haswell
Clang: 12.0 build 1200
Git: 2.24.3 => /Library/Developer/CommandLineTools/usr/bin/git
Curl: 7.64.1 => /usr/bin/curl
macOS: 11.1-x86_64
CLT: 12.3.0.0.1.1607026830
Xcode: N/A
</pre>
<pre>
toast % brew doctor
Your system is ready to brew.
</pre>
Ah, lastly, the reason Caddy cannot find $HOME is because Homebrew filters the environment variable list before running the service To help troubleshoot this, they need to modify the service running command to include the flag --environ, which causes Caddy to print the environment variables as it sees them in the system and helps knowing how it perceives the world.
@ctbritt what changed, beside going from Pi 4 to Pi 5?
Can diffing the Pi 4 configs with the Pi 5 be done?
