Sadly, it’s not possible to show the diff logs.
the only thing that’s changed is the hardware swapout and making sure all the ports etc. are set up. They’re all identical to the old set up.
Understood, but actually I had asked for a diff of the configurations. ![]()
Well, I finally fixed it. I deleted all the certs, upgraded caddy, and simplified my caddy file. it’s now this:
# This replaces the existing content in /etc/caddy/Caddyfile
# A CONFIG SECTION FOR YOUR IP AND HOSTNAME
default_sni 192.168.5.86
email callbritton@mac.com
192.168.5.86 {
# PROXY ALL REQUEST TO PORT 30000
tls internal
reverse_proxy localhost:30000
encode zstd gzip
foundry.azthir-terra.com {
encode zstd gzip
5e.azthir-terra.com {
# PROXY ALL REQUEST TO PORT 5000
root * /Volumes/foundrydisk/5etools-mirror-2.github.io/
file_server browse
encode zstd gzip
192.168.7.121 {
# PROXY ALL REQUEST TO PORT 50000
tls internal
reverse_proxy raspberrypi.local:50000
encode zstd gzip
pi.azthir-terra.com {
encode zstd gzip
Now I can ssh into my pi from both inside and outside the network, and get a secure connection to all of the machines and domains.
thanks everyone for their help!
C
