Caddyfile for Django API and SPA
v2.1.1
Caddy is run as a system unit.
Ubuntu 20.04
./caddy validate Caddyfile
sudo systemctl restart caddy
mydomain.com {
        output stdout
        level DEBUG
    reverse_proxy /admin* 127.0.0.1:8000
    reverse_proxy /api* 127.0.0.1:8000
    file_server /static/* {
        root /path/to/back
    file_server /media/* {
        root /path/to/back
    try_files {path} /index.html
    file_server /* {
        root /path/to/front/dist
I’m serving both a Django API and a SPA. I’m trying to use try_files directive (similar to what I used in Nginx) but failing at finding the proper configuracion.
Initially I had this configuration:
    file_server /* {
which works ok for mydomain.com but cannot load mydomain.com/team. So I’m trying to change it to serve the SPA correctly.
I’ve tried other modifications (apart from the shown in the d section) in the Caddyfile like:
root /* /path/to/front/dist
or
The configuration seems fine (it validates), but I cannot reach mydomain.com/team which is expected.
Thank you for your help!
Me again! After pairing with a colleague, we found this answer which was helpful. I’ll let here the final configuration that works:
mydomain.com {
        output stdout
        level DEBUG
    root /static/* /path/to/back
    root /media/* /path/to/back
    root * /path/to/front/dist
    route {
        try_files {path} {path}/ /index.html
Glad you figured it out!
FYI, it’s very slightly more efficient to use root * /path/to/front/dist rather than /* because /* is a path matcher which will always match, whereas * will just match every request without doing a path comparison.
Thanks for your tip! I’ll add it to the solution, should anyone copy and paste it.
