Caddy v2 wesocket load balance
Hello. Can I use load balance policy for websocket reverse proxy? Can’t find any docs.
v2.6.4
docker run caddy:v2.6.4
caddy run --config /etc/caddy/Caddyfile
reverse_proxy 1.1.1.1:82 1.1.1.2:82 {
	header_regexp Connection *Upgrade*
	header        Upgrade websocket
These are invalid config inside reverse_proxy.
Caddy’s reverse_proxy supports proxying WebSocket connections out of the box, there’s nothing extra to do.
This will automatically load balance across the two backends, using the default lb_policy of random. See the docs: reverse_proxy (Caddyfile directive) — Caddy Documentation
Setting up load balancing involves a lot of questions to get it right. You probably want to also enable retries, and active/passive health checking so that Caddy can figure out which upstreams are unhealthy.
This is configuration is valid for ws? I get config from Websockets over https
  header Connection *Upgrade*
No, that’s wrong.
All you need is this, to start:
You don’t need to do anything with headers for WebSockets. It’s completely automatic.
But like I said, you do need to configure more things for load balancing. See the docs.
