Websockets over https
1. Output of caddy version:
image: lucaslorentz/caddy-docker-proxy:ci-alpine
- 80:80
- 6001:6001
- CADDY_INGRESS_NETWORKS=routable
- routable
- ./caddy_data:/data
- ./certs:/certs
RockyLinux 8.6/Docker
docker-compose up -d
version: "3.7"
      - 80:80
      - 6001:6001
      - routable
      - ./certs:/certs
  routable:
    external: true
dev.traefik.listech.on.ca:80 {
    reverse_proxy
http://gitlab.listech.on.ca {
    reverse_proxy http://172.17.63.3:80
    tls internal
staging.h1.listech.on.ca {
    reverse_proxy 172.17.63.5
    tls /certs/h1/certificate.crt /certs/h1/private.key
staging.h1.listech.on.ca:6001 {
    @ws {
    header Connection *Upgrade*
    header Upgrade websocket
reverse_proxy @ws https://172.17.63.2:6001
I am trying to serve my internal (no outside access) websocket server over tls. The caddy configuration was working fine without tls on it or the main container (:80). When my client attempts to connect to the server via port 6001 it gets a 502 Bad Gateway response. TLS is working for the main container on port 443.
Log was too long for this post, link to log on Pastebin
https://pastebin.com/CQvWe6Se
Lots of googling. I’m pretty new to using caddy so I have not been too sure what to try. I have been trying to find any nugget of information that could lead me downt he right path to a solution
This is how I am using Caddy in docker
I’m going to guess your issue is that you used https:// here, but your upstream app isn’t actually using HTTPS.
Why are you using a different port for websockets?
You can simplify your setup by multiplexing your app and websockets in the same site, using a matcher to determine if the request is WS or simply normal HTTP.
Try this:
	# Websockets, if headers match
	@ws {
	reverse_proxy 172.17.63.2:6001
	# Main app
	reverse_proxy 172.17.63.5:80
Of course, you’ll need to update your frontend config to use wss://staging.h1.listech.on.ca to connect (remove the :6001 port from the connection address)
So I made changes as you suggested but I’m still getting an error from caddy
    "level": "error",
    "ts": 1660835989.096334,
    "logger": "http.log.error",
    "msg": "EOF",
    "request": {
        "remote_addr": "10.2.32.207:58041",
        "proto": "HTTP/1.1",
        "method": "GET",
        "host": "staging.h1.listech.on.ca",
        "uri": "/",
        "headers": {
            "Upgrade": [
                "websocket"
            "Sec-Websocket-Key": [
                "qp/gAHEq0lmlghZMep6kdQ=="
            "Connection": [
                "Upgrade"
            "Origin": [
                "https://staging.h1.listech.on.ca"
            "Sec-Websocket-Version": [
                "13"
        "tls": {
            "resumed": false,
            "version": 771,
            "cipher_suite": 49199,
            "proto": "",
            "proto_mutual": true,
            "server_name": "staging.h1.listech.on.ca"
    "duration": 0.001523141,
    "status": 502,
    "err_id": "d8uyaqa5j",
    "err_trace": "reverseproxy.statusError (reverseproxy.go:886)"
Here is my up to date caddyfile. I will note
    debug True
    reverse_proxy
    tls internal
    @ws {
    reverse_proxy 172.17.63.5 172.17.63.4:6001
This should just be debug
This reverse proxies to nothing, is that intended?
You can remove http:// here
Doesn’t make sense to use this for an http:// site.
This matcher is never used, so you can remove it.
This load balances between 172.17.63.5 and 172.17.63.4:6001 – is that intended? It’s basically a random selection.
Not my intention, let me explain further what I’m doing. app is just a normal webserver and I also need a websockets server also available at the same url, I had this working before I attempted tls by using caddy to expose port 6001 but when I added tls to the app container I could no longer access my websocket server. At this point though as per the first responders suggestion removing the additional port and just routing the traffic based on whether it’s https or ws/wss.
I have these two containers that I want exposed via the staging.h1.listech.on.ca url.
app:
    image: lti-alpine:1.21.4-alpine
    build:
      context: ./dockerfiles
      dockerfile: nginx.dockerfile
      args:
        - UID=${UID:-1000}
        - GID=${GID:-1000}
    labels:
      caddy: "staging.h1.listech.on.ca"
      caddy.tls: /certs/h1/certificate.crt /certs/h1/private.key
      caddy.0_reverse_proxy: "{{upstreams}}"
      - ./cert:/cert
      - ./web:/var/www/html:delegated
    depends_on:
      - php
      - redis
      - mailhog
      - websockets
      - h1project
      - routable
websockets:
    image: lti-php:8.1-fpm-alpine
      - ./cert:/cert
    working_dir: /var/www/html
    expose: [6001]
    labels:
      caddy: staging.h1.listech.on.ca
      # caddy.tls: /certs/h1/certificate.crt /certs/h1/private.key
      caddy.@ws.0_header: Connection *Upgrade*
      caddy.@ws.1_header: Upgrade websocket
      caddy.1_reverse_proxy: "@ws {{upstreams 6001}}"
    entrypoint: ["php", "/var/www/html/artisan", "websockets:serve"]
      - routable
      - h1project
I made some changes to my docker-compose file to fix issues with my in-memory caddyfile that the caddy docker image generates
http://gitlab.listech.on.ca:80 {
    tls internal
    @ws {
    reverse_proxy @ws 172.17.63.4:6001
So is that working now? That looks good to me.
Still wasn’t working but I was able to get it going, in a slightly different way. The docs for my websocket server were updated with some more information on using TLS.
I didn’t enable TLS on the websocket server but left it on caddy and proxied as needed, here is my updated caddy file. At this point
    tls internal
    @ws {
    reverse_proxy 172.17.63.4
    reverse_proxy @ws http://172.17.63.2:6001
