@matt maybe a good idea to at least set some form of defaults for some timeouts for slowris HTTP like DOS attacks ?
So I want to replicate my Nginx client_body_timeout and client_header_timeout values of 10s, in Caddy v2 is this correct way for my HTTPS site = srv1 ?
curl -s localhost:2019/config/ | jq -r '.apps.http.servers.srv1' > srv1.json
curl localhost:2019/config/apps/http/servers/srv1/read_timeout -X POST -H "Content-Type: application/json" -d '"10s"'
curl localhost:2019/config/apps/http/servers/srv1/read_header_timeout -X POST -H "Content-Type: application/json" -d '"10s"'
curl -s localhost:2019/config/ | jq -r '.apps.http.servers.srv1' > srv1-timeouts.json
diff -U20 srv1.json srv1-timeouts.json
--- srv1.json 2020-05-12 15:24:22.665049146 +0000
+++ srv1-timeouts.json 2020-05-12 15:25:03.672282315 +0000
@@ -1,29 +1,31 @@
"listen": [
":4444"
"logs": {
"logger_names": {
"caddy2.domain.com:4444": "log1"
+ "read_header_timeout": "10s",
+ "read_timeout": "10s",
"routes": [
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "vars",
"root": "/usr/share/caddy"
"handler": "headers",
"response": {
"set": {
"X-Powered-By": [
"caddy centminmod"
and full srv1 JSON config would be
cat srv1-timeouts.json
"listen": [
":4444"
"logs": {
"logger_names": {
"routes": [
"handle": [
"routes": [
"handle": [
"handler": "vars",
"response": {
"set": {
"X-Powered-By": [
"caddy centminmod"
"response": {
"set": {
"X-Content-Type-Options": [
"nosniff"
"response": {
"set": {
"X-Xss-Protection": [
"1; mode=block"
"encodings": {
"gzip": {}
"handler": "encode"
"handler": "file_server",
"hide": [
"/etc/caddy/Caddyfile"
"match": [
"host": [
"caddy2.domain.com"
"terminal": true
"tls_connection_policies": [
"match": {
"sni": [
"caddy2.domain.com"
so once I use JSON method, my Caddyfile is obsolete according to API Tutorial — Caddy Documentation
Important note: This should be obvious, but once you use the API to make a change that is not in your original config file, your config file becomes obsolete. There are a few ways to handle this:
Use the --resume of the caddy run command to use the last active config.
Don't mix the use of config files with changes via the API; have one source of truth.
Export Caddy's new configuration with a subsequent GET request (less recommended than the first two options).
does that mean --resume command last active is before the JSON POST change or is with the JSON POST change ?
not entirely clear when last option for exporting caddy’s new configuration does ? it syncs JSON POST change with Caddyfile so I can do Caddyfile changes + retain JSON POST changes ? or Caddyfile changes no longer work and need to do all subsequent site changes via JSON ?
