I’m currently using caddy on windows as a reverse proxy. I’m migrating hosts and switching over to unraid. I have the caddy docker up and running just not sure where to start.
Docker you on unraid
paste command here
paste full file contents here
On windows once I had caddy up and running I just created a json file and when I started the service caddy did everything for me and it’s been amazing!
Now that I’m setting up this docker I’m unsure of how to create the caddyfile so that caddy can be just as amazing but now running in a container.
I’m not trying to be vague it’s just I can’t find any documentation on how to configure this docker to work as a reverse proxy. I really love caddy and have recommended it to everyone and their brother but I’m a life long windows guy taking the docker plunge.
thanks again for your help! i figured i could just drop in my caddy file and start the container but when i browse to the directory in the documentation there is no caddy folder.
so i created the path /etc/caddy and dropped in my Caddyfile. I then ran caddy fmt /etc/caddy/Caddyfile and got an error stating no such file exists.
Then I edited the file by using cli and vi. Did a caddy reload and now it looks like it does a forced https but isn’t proxying back to where it should be.
In unraid all of my dockers install to /mnt/user/appdata/ but I couldn’t find the files for the caddy docker. In the documentation for caddy I saw mention of /etc/caddy/caddyfile for the location of the file. I browsed out to that location but it didn’t exist. So under /etc/ I created the caddy folder then copied over my existing caddyfile. Then I just ran the caddy command to point to my caddyfile. It’s been working great since. I’m just not sure if that file will ever get over written so I have a backup handy.
To Brian and others that may have questions in the future:
There is an unRaid Docker template for Caddy. This gives all the required ports/volumes so they are more easily identified.
Just add the following to “Template Repositories” under the “Docker” tab in unRAID:
