most recent
as a service
Ubuntu 18
paste full file contents here
http://whatup.ga {
reverse_proxy 127.0.0.1:8096
Redirect to the port happens but NOT secured.
I’ve had Caddy working great for reverse proxy and SSL for a long time. Today I did a sudo apt upgrade to get the server up to date. Everything seems to be working except now there’s no SSL.
Well, you did put http:// in front of your domain, so of course it won’t serve HTTPS!
You know what’s worse than making such a silly mistake? I’ve made it and posted about it before. If I were you, I’d ban me.
It’s actually your 3rd time, one in each of the threads you’ve posted
Yep, just remove http:// from the front and you should be done.
Just as a note for next time; this is exactly why redacting parts of your config or modifying it before posting it on the forums is always a mistake. We went in circles a few times because we didn’t have evidence of the issue because you didn’t post your exact config.
But no worries, hopefully you’ve fixed it once and for all.
