Hello, I’m currently running Caddy 2.7 in a docker compose + Dockerfile combination. When I build the compose, everything installs fine. However, when I run docker compose -f caddy-compose up -d and check the logs of caddy, it will show caddy exited with code 0 and then restart the container since the container has the property restart: unless-stopped. I’m not sure why it keeps exiting. I need to use Caddy + Cloudflare because my DNS A record is needed without a cloudflare proxy and CANNOT be used with a Cloudflare proxy and I’m attempting to use a Caddy’s automatic HTTPS feature with Let’s Encrypt with an ACME DNS-01 challenge.
My goal is to automatically have a https certificate that is trusted by the browser and Cloudflare’s Origin Server CA that I manually created isn’t.
No other errors are shown other than this since it repeatedly restarts and exits.
Caddy v2.7-builder
Ubuntu 22.04
Docker Engine: Built with Docker compose + Dockerfile
docker compose -f caddy-compose.yml build
docker compose -f caddy-compose.yml up -d
docker compose -f caddy-compose.yml logs -f
caddy-compose.yml
version: "3.7"
build:
context: .
dockerfile: Dockerfile
- "443:443/udp"
- /home/user/homelab/caddy/configs/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/user/homelab/caddy/configs/caddy/site:/srv
- /home/user/homelab/caddy/configs/caddy/caddy_data:/data
- /home/user/homelab/caddy/configs/caddy/caddy_config:/config
- /etc/ssl:/etc/ssl
- caddy-network
caddy-network:
external: true
caddy_data:
external: true
caddy_config:
Dockerfile
FROM caddy:2.7-builder AS builder
RUN xcaddy build \
Possibly relevant information: The Jellyfin service is connected through caddy with the externally available caddy-network. Domain was originally bought on GoDaddy and changed the name servers so I could use it on Cloudflare. I wasn’t sure if I needed email or not. I have another service running on port 8080, its docker file has the following information:
Complete Caddyfile
ports
- "8080:8080"
email example@icloud.com
server.exampledomain.com {
dns cloudflare REDACTED
reverse_proxy jellyfin:8096
- I tried following the second option, Use Caddy’s automatic HTTPS feature with Let’s Encrypt
Initial Setup was with this Caddy + Docker tutorial video:
Additional docker resources I used to create a custom build:
