Building caddy with dns provider module and docker getting caddy_build exited with code 0
Hello, I try to build caddy with the dns provider module using the :builder image with docker compose. My goal is to be able to have automatic https using the DNS challenge. However once built and started the container appears to keep restarting. I get this error “caddy_build exited with code 0” I ran docker compose build and then docker compose up. I seem to be unable to get more details regarding what is going wrong. I think this is because the container keeps restarting. Below is what is output to the terminal from the compose build step and then the compose up step. I’m not sure how to figure out what could be wrong. As a side note, I can confirm I can successfully get Caddy 2.9-alpine docker image running on this environment when I don’t try building with plugins. Seems the trouble lies with building with plugins.
[+] Building 243.3s (8/8) FINISHED        docker:default
 => [caddy internal] load build definition from Dockerfile        0.0s
 => => transferring dockerfile: 223B        0.0s
 => [caddy internal] load metadata for docker.io/library/caddy:2.9-builder-alpine        0.2s
 => [caddy internal] load .dockerignore        0.0s
 => => transferring context: 2B        0.0s
 => CACHED [caddy builder 1/2] FROM docker.io/library/caddy:2.9-builder-alpine@sha256:192533a0715e00011c17b9622e9eb343ef751658efe0a8b5e8444805475a5ce9                              0.0s
 => [caddy builder 2/2] RUN xcaddy build     --with github.com/caddy-dns/porkbun        242.1s
 => [caddy stage-1 2/2] COPY --from=builder /usr/bin/caddy /usr/bin/caddy        0.1s
 => [caddy] exporting to image        0.2s
 => => exporting layers        0.2s
 => => writing image sha256:78f88b88b6f78633f2fda2f26d3aa19d27775d46d156df0f0cdc232733eb5347        0.0s
 => => naming to docker.io/library/caddy-build-demo-pk-caddy        0.0s
 => [caddy] resolving provenance for metadata file
 docker compose up
[+] Running 3/3
 ✔ Volume "caddy-build-demo-pk_caddy_build_config"  Created        0.0s
 ✔ Volume "caddy-build-demo-pk_caddy_build_data"    Created        0.0s
 ✔ Container caddy_build                            Created        0.1s
Attaching to caddy_build
I’m unable to get the output of the verison from the docker compose exec caddy caddy version command, it outputs that the container is restarting, wait until the container is running.
Digital Ocean Droplet running Docker on Ubuntu 22.04
Docker version 27.3.1, build ce12230
Docker Compose version v2.30.3
buildx v0.17.1 257815a
docker compose up
My compose.yml
    container_name: caddy_build
    build: .
      - "443:443/udp"
      - ./site:/srv
      - caddy_build_data:/data
      - caddy_build_config:/config
  caddy_build_data:
  caddy_build_config:
My Dockerfile
FROM caddy:2.9-builder-alpine AS builder
RUN xcaddy build \
My .env file
PORKBUN_API_KEY="redacted"
PORKBUN_API_SECRET_KEY="redacted"
My site directory contains an index.html containing
<h1>Hello World</h1>
doporkbun.superherodonut.com {
	dns porkbun {
			api_key {env.PORKBUN_API_KEY}
			api_secret_key {env.PORKBUN_API_SECRET_KEY}
  root * /srv
Similar error this user experienced not sure if they ever were able to resolve.
Try this instead:
BUILDKIT_PROGRESS=plain docker compose build
This will change the output to show everything going on. Show the error you get.
Actually, this is normal output, not an error. Exit code 0 means the program exited “with no error”.
Your containers seem to be running, do docker compose ps to see them.
Oh this is your issue, you need FROM caddy:2.9-alpine here, not -builder-alpine. You’re meant to copy the output from the builder image on top of the regular non-builder image, with which Caddy actually runs.
Thank you! It helped me making my own caddy 2.9 docker image with Porkbun cababilities! For anyone finding this and wanting the image hassle-free, here is the one i created.
WARNING: You should not rely on images some stranger created as it can contain mislicious actions. In this case, i just copied OP’s Dockerfile as it looks right and non-suspicious but you should do your own research and determine if my image is really harmless. Ideally, build your own image.
Thank you very much for your help! This was exactly what was messing me up.
