Caddy bring up weird error about pb.proto
1. Caddy version (caddy version): v2.1.0
2. How I run Caddy:Ubuntu 20.04 LTS with the default apt install from the guides section
a. System environment: Ubuntu 20.04 LTS, Systemd, apt install
b. Command: any caddy command brings up the error
caddy.service
# for your installation.
After=network.target
# domain name.
:80
root * /usr/share/caddy
# php_fastcgi localhost:9000
3. The problem I’m having: Whenever I run any caddy command I get an error talking about something I don’t understand at all and google yields zero results
myusername@myhostname:~$ caddy
2020/06/29 19:07:12 WARNING: proto: file “pb.proto” is already registered
A future release will panic on registration conflicts. See:
https://developers.google.com/protocol-buffers/docs/reference/go/faq#namespace-conflict
Caddy is an extensible server platform.
usage:
caddy [<args…>]
commands:
adapt Adapts a configuration to Caddy’s native JSON
build-info Prints information about this build
environ Prints the environment
file-server Spins up a production-ready file server
fmt Formats a Caddyfile
hash-password Hashes a password and writes base64
help Shows help for a Caddy subcommand
list-modules Lists the installed Caddy modules
reload Changes the config of the running Caddy instance
reverse-proxy A quick and production-ready reverse proxy
run Starts the Caddy process and blocks indefinitely
start Starts the Caddy process in the background and then returns
stop Gracefully stops a started Caddy process
trust Installs a CA certificate into local trust stores
untrust Untrusts a locally-trusted CA certificate
validate Tests whether a configuration file is valid
version Prints the version
Use 'caddy help ’ for more information about a command.
Full documentation is available at:
5. What I already tried: Purging the install and trying it three times. Searching the pc for the file it’s talking about nothing comes up. looked all over google nothing comes up. Went to page it tells me to visit it made absolutely no sense to me.
I had this same question. Here’s the response
You shouldn’t need to worry about it.
Thanks for the response.
We’ll soon release a v2.1.1 that fixes this warning - it was an unintended regression from v2.0
