v2.1.0 h1:MC4d65RCVaEKy1iOFjsD51mybOwS8qdEVBi7ESDhUfE=
system service
raspberry pi 4 (buster)
direct install
start or run
n/a
The Caddyfile doesn’t matter as I tried different ones and it doesn’t stop the WARNING
mydomain.duckdns.org {
root * /srv/dev-disk-by-label-HomeDrive/config files/users
file_server browse
I get the following every time I enter anything into the terminal with caddy
2020/06/27 08:43:08 WARNING: proto: file "pb.proto" is already registered
A future release will panic on registration conflicts. See:
https://developers.google.com/protocol-buffers/docs/reference/go/faq#namespace-conflict
This started after my upgrade to 2.1. The method of upgrading was using apt
I went to the link and read about it. It’s far above my head to understand though. I also found this issue already brought up on the GitHub https://github.com/caddyserver/caddy/issues/3525
Is this going to be an issue for my system? So far Caddy seems to be working just like it was for the guy who posted in GitHub. @Mohammed90 said it could be fixed by downgrading but I haven’t the slightest on how to do that.
Should I just leave it alone and wait for a fix? Any help would be great. Thank you.
