Add dns entry to Opensense / Hooks?
TL;DR: I want caddy to manage unbound host overrides to set local DNS entries. Question is there module / way to invoke a hook script?
I just found out that you can set a unbound host overrides via api on opnsens:
curl -X POST -d \
  '{"host":{"enabled":"1","hostname":"test","domain":"testdomain.com","rr":"A","mxprio":"","mx":"","server":"10.0.1.1","description":""}}' \
  -H "Content-Type: application/json" \
  -u ${key}:${secret} \
  https://opnsense.local/api/unbound/settings/add_host_override
And my fist Idea was to use this in combination with caddy. It would be awesome to be able to set local dns entries using caddy. But I don’t really know how I could do this. I searched and the only thing remotely close to it was this: Use Caddy for local HTTPS (TLS) between front-end reverse proxy and LAN hosts
But I would need some post DNS creation hook that sends the request to opnsense, but I haven’t found anything related to this. But I may also just don’t know what I need to search for.
Is there anything that I can use to do this? Or would I need to write a module to do so and where would I need to begin?
None
docker-compose
docker
docker compose up
FROM caddy:2-builder AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/porkbun \
    --with github.com/mholt/caddy-dynamicdns \
    --with github.com/mietzen/caddy-dynamicdns-cmd-source
FROM caddy:2
    build: .
    cap_add:
      - NET_ADMIN
      - "443:443/udp"
      - /opt/docker/caddy/conf:/etc/caddy
      - caddy_data:/data
      - caddy_config:/config
      - caddy
  caddy_data:
  caddy_config:
    external: true
Does not exist at this point
Oh I think I can answer my own question:
I going to test this.
Edit: This is totally doable :+1: I love caddy :heart:
You need this module: GitHub - mholt/caddy-events-exec: Run commands on Caddy events
Caddyfile:
    events {
        on cert_obtained exec echo "MY DOMAIN: {event.data.identifier}"
Log:
2025/08/20 14:15:46.226	INFO	tls.obtain	releasing lock	{"identifier": "sub.example.com"}
MY DOMAIN: sub.example.com
For anyone who is curious, what event.data looks like:
map[
	certificate_path:certificates/acme-v02.api.letsencrypt.org-directory/wildcard_.sub.example.com/wildcard_.sub.example.com.crt
	csr_pem:[10 11 ...]
	identifier: sub.example.com
	issuer:acme-v02.api.letsencrypt.org-directory
	metadata_path:certificates/acme-v02.api.letsencrypt.org-directory/wildcard_.sub.example.com/wildcard_.sub.example.com.json
	private_key_path:certificates/acme-v02.api.letsencrypt.org-directory/wildcard_.sub.example.com/wildcard_.sub.example.com.key
	renewal:false
	storage_path:certificates/acme-v02.api.letsencrypt.org-directory/wildcard_.sub.example.com
