Zstd not working?! (caddy always prefers gzip)
1. Output of caddy version:
systemd
Distributor ID: Ubuntu
Description: Ubuntu 22.04 LTS
Release: 22.04
Codename: jammy
systemd 249 (249.11-0ubuntu3.4)
+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified
systemd
Type=notify
Caddyfile:
import /etc/caddy/snippets/global.conf
import /etc/caddy/sites/*.conf
(encoding) {
    encode zstd gzip
sites/example.conf
example.com {
    root * /var/www/example.com/httpdocs
    # IMPORT DEFAULTS
    import encoding
Caddy uses always gzip instead of zstd, no matter what I try. My network analysis shows content-encoding: gzip. Is there a possibility that I need to install zstd on the OS? E.g. apt install zstd (if yes, then this should be mentioned in the caddy docs) or is zstd directly integrated in the compiled caddy application? There seems to be no additional output / logs to warn the user about this behavior.
No errors.
I’ve placed “encode zlib gzip” directly in the sites configuration. But there is no difference, caddy always uses gzip no matter what I do or try.
Almost no clients support Zstandard. :frowning:
Thank you! I didn’t know this, this saves me the headache of searching further and wasting time :smiley: It’s really strange all the tutorials I read didn’t mention this.
To clarify, it’s not a problem with Caddy or what you have installed. Caddy uses a pure-Go implementation of zstd, so it’s bundled with Caddy. We use GitHub - klauspost/compress: Optimized Go Compression Packages for our compression needs.
But yeah, most browsers don’t have zstd support. Chrome and Firefox support gzip, deflate, br – that’s what they send in the Accept-Encoding header.
Gzip and Deflate are very similar – same underlying compression algorithm, but they differ in their header/footer info and the checksum algorithm used. See asp.net - What is the advantage of GZIP vs DEFLATE compression? - Stack Overflow
Caddy doesn’t support Brotli out of the box because there’s no fast pure-Go implementation yet. Brotli is pretty slow at compressing, but produces smaller results with still-very-good decompression performance. So it’s a good option when pre-compressing files, and Caddy’s file_server can serve these pre-compressed files for you if you need. But that’s a more advanced usecase and depends on your site’s build tooling to support it.
