Xcaddy not found using caddy:2.1.0-builder
I am trying to build a custom container image using caddy:2.1.0-builder and getting “/bin/sh: xcaddy: not found”. My Dockerfile:
FROM caddy:2.1.0-builder AS builder
RUN xcaddy build \
    --with github.com/mholt/caddy-ratelimit@v0.1.0
FROM caddy:2.1.0
I haven’t used Docker all that much so it is quite possible I am doing something stupid.
docker build -t caddy:latest .
[+] Building 2.4s (7/8)        docker:orbstack
 => [internal] load build definition from Dockerfile        0.0s
 => => transferring dockerfile: 252B        0.0s
 => [internal] load metadata for docker.io/library/caddy:2.1.0        2.1s
 => [internal] load metadata for docker.io/library/caddy:2.1.0-builder        0.0s
 => [internal] load .dockerignore        0.0s
 => => transferring context: 2B        0.0s
 => CACHED [builder 1/2] FROM docker.io/library/caddy:2.1.0-builder        0.0s
 => CACHED [stage-1 1/2] FROM docker.io/library/caddy:2.1.0@sha256:9ee709b080aacb1a5cae6c4cb654d950f1ded75d7a2277a792860bb28134158e                                              0.0s
 => ERROR [builder 2/2] RUN xcaddy build     --with github.com/mholt/caddy-ratelimit@v0.1.0        0.2s
 > [builder 2/2] RUN xcaddy build     --with github.com/mholt/caddy-ratelimit@v0.1.0:
0.150 /bin/sh: xcaddy: not found
Dockerfile:3
   2 |
   3 | >>> RUN xcaddy build \
   4 | >>>     --with github.com/mholt/caddy-ratelimit@v0.1.0
   5 |
ERROR: failed to solve: process "/bin/sh -c xcaddy build     --with github.com/mholt/caddy-ratelimit@v0.1.0" did not complete successfully: exit code: 127
Mac OS 15.4. Apple M3 Max.
Docker version 28.0.4, build b8034c0
https://hub.docker.com/_/caddy
Thanks
It should be .10, not .1
