Xcaddy and existing caddy installation
This isn’t necessarily help but a question, I currently have caddy installed on bare metal using the ubuntu guide. I need to get caddy working with Crowdsec and it looks like I gotta use xcaddy and add a plugin, I wanted to ask if I were to use xcaddy to rebuild, would it take care of the existing installation and overwrite it with the new caddy with the plugin I need?
I hope my question made sense, thank you in advance.
Follow these instructions to set up Caddy to run with your custom build as a service:
