X-Forwarded-Proto keeps being http
I’m trying to get X-Forwarded-Proto to be https. From the docs it seems like I shouldn’t need to do anything. Caddy is NOT behind a proxy so the requests it gets should contain no X-Anything
There are no log messages, it proxies the request as expected, all the X-Forwarded headers look right, EXCEPT for -Proto and it is always http
Co-worker installed Caddy, not sure how, and not sure if that matters for this question. He’ll be back from vacation soon.
Ubuntu 22.04.2 LTS
/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
service file
; Ansible managed
; source: https://github.com/mholt/caddy/blob/master/dist/init/linux-systemd/caddy.service
; version: 6be0386
; changes: Set variables via Ansible
After=network-online.target
StartLimitIntervalSec=86400
StartLimitBurst=5
Restart=on-failure
User=www-data
Group=www-data
ExecStart="/usr/local/bin/caddy" run --environ --config "/etc/caddy/Caddyfile"
ExecReload="/usr/local/bin/caddy" reload --config "/etc/caddy/Caddyfile"
; Use a minimal /dev
PrivateDevices=true
ProtectHome=true
; ... except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
;   This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/ssl/caddy /var/log/caddy
; They further restrict privileges that can be gained by caddy.
NoNewPrivileges=true
e2e1.qa.dubclub.win {
	reverse_proxy http://e2e1.rhino-jazz.ts.net
e2e2.qa.dubclub.win {
	reverse_proxy http://e2e2.rhino-jazz.ts.net {
		header_up X-Forwarded-Proto https
e2e3.qa.dubclub.win {
	reverse_proxy http://e2e3.rhino-jazz.ts.net
I’ve also tried including https in quotes “https”. But still no change,
Please enable the debug global option and show your Caddy logs. Make a request with curl -v and show what that looks like as well.
The problem is NOT with caddy. It was with nginx which was behind Caddy. Caddy is the gateway from the internet into our tailnet and then each server has nginx to serve static files and proxy to gunicorn. The problem had nothing to do with Caddy and everything to do with nginx. I’ve solved part of the issue with nginx but not all of it yet. Still having problems with X-Forwarded-For having 2 IPs in it, one from the client and one from the caddy server. Sorry for the trouble.
That sounds normal. Proxies are supposed to append the direct connecting client’s IP address to the header, if they trust the downstream proxy. By default, Caddy distrusts all connecting clients (unless you configure trusted_proxies), so it will only contain the IP of the direct connecting client and throw away the incoming XFF header. Your nginx might be adding Caddy’s IP to the header, and that should be fine. It’s up to your application to parse the header and get the IP address it needs from it.
Yea. It was nginx that was creating the problems. Caddy was doing it exactly right but nginx had not been setup to sit behind another proxy. I solved the issue by changing the default proxy_params to be
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-For $http_x_forwarded_for;
proxy_set_header X-Forwarded-Proto https;
proxy_headers_hash_max_size 2048;
proxy_headers_hash_bucket_size 128;
The last 2 lines were suggestions from sudo nginx -t
