I have just installed Authelia (light) and managed my first authentication to whoami
with the new forward_auth
implementation (THANK YOU for that!)
https://whoami.example.eu {
forward_auth authelia:9091 {
uri /api/verify?rd=https://auth.example.eu
copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
reverse_proxy whoami:80
I have all the containers dockerized, the host is 192.168.10.2
, its gateway is 192.168.10.1
(this is my router, connected to the fiber)
caddy
on127.18.0.20
(127.18.0.0/16
is my default docker network) -
authelia
on127.18.0.34
whoami
on127.18.0.35
When going to https://whoami.exemple.eu
I get authelia’s authentication screen and after a successful login I see whoami
output:
Hostname: 1eb10164839a
IP: 127.0.0.1
IP: 172.18.0.35
RemoteAddr: 172.18.0.20:40140
GET / HTTP/1.1
Host: whoami.exemple.eu
Referer: https://auth.example.eu/
Remote-Email: (...)
Upgrade-Insecure-Requests: 1
X-Forwarded-For: 192.168.10.1
X-Forwarded-Host: whoami.exemple.eu
X-Forwarded-Proto: https
What I do not understand is why in no place I see the IP of my laptop from which I did the call (192.168.10.11
) but the only
IP: 172.18.0.35
→whoami
(OK) -
→caddy
(why?) -
→ my router (why?)
The result is the same without Authelia (just using reverse_proxy
to whoami:80
, it is just I discovered it now.
I expected both RemoteAddr
and X-Forwarded-For
to point to my laptop (or at least X-Forwarded-For
) but this is not the case.
Is there something I should configure to have the right information at the container level? (= provided to the containers behind caddy
EDIT: I see that @WoJ already posted a similar problem two years ago (How to set X-Forwarded-For so that it contains the IP of the original caller?) but that noob made a configuration mistake (he he he), so this question is much better
