Www subdomain insecure
Getting a Secure Connection Failed SSL_ERROR_INTERNAL_ERROR_ALERT error on the www. subdomain of my site. I can reach the naked domain as expected, but cannot reach the www. subdomain as browser thinks it is insecure.
I’ve got an Ubuntu 20.04 server running on Digital Ocean. I followed this tutorial to get Caddy running.
Digital Ocean domain settings:
  • A record with example.com as hostname that directs to my DO server IP address
  • CNAME with www.example.com as hostname that is an alias of A record hostname
Browser error message when trying to visit www.example.com:
Built Caddy from xcaddy, with the digitalocean dns plugin.
I followed the instructions on a Digital Ocean tutorial. While it is recommended to use the official Caddy install docs, the DO guide seems similar enough to the Caddy docs, but also provides further details that the Caddy docs seemed to assume.
Ubuntu 20.04
sudo systemctl restart caddy # restart caddy
sudo systemctl enable caddy # enable caddy so it runs on boot
Type=notify
Environment=DO_AUTH_TOKEN=[redacted]
zelip.org {
    root * /var/www
        dns digitalocean {env.DO_AUTH_TOKEN}
The instructions I used to build/use Caddy, How To Host a Website with Caddy on Ubuntu 22.04 | DigitalOcean
It seems that your config doesn’t tell Caddy to serve the www subdomain:
zelip.org {
Try this:
zelip.org, www.zelip.org {
Super easy! Thanks Matt!
Just realized the docs already have this issue covered, sorry! :person_facepalming:
